I purchased one UV sensor grove in seeed, which is an expansion to measure the intensity of incident ultraviolet(UV) radiation. For creating the value which displays on the OLED of the weather station, I tried to connect the UV sensor grove to the expansion interface of the station. Following the wiki of the UV sensor grove, I have finished the programming. Now, show the result I tried.
Makerfabs
