I coded the whole thing in C to make sure my logic is sound.
Hit a few bumps in interfacing SPI with the MAX7219 LED Matrix but it worked eventually
Implemented a simple ballChase algorithm for the computer's paddle to make things easier for me while coding in assembly. The downside is you can never win against the computer :P
#include <SPI.h>
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
#define LB 7
#define RB 6
#define lo8(x) ((x)&0xff)
#define hi8(x) ((x)>>8)
int playerPaddle = 2;
int compPaddle = 2;
int compDirection = 1;
int ballx = 6;
int bally = 4;
int speedx = 1;
int speedy = -1;
boolean gameOver = false;
uint16_t buffer = 0 ;
void refresh(){
for(int i=1;i<=8;++i)
if(i==(playerPaddle-1)|i==(playerPaddle)|i==(playerPaddle+1))
bitSet(buffer,0);
if(i==(compPaddle-1)|i==(compPaddle)|i==(compPaddle+1))
bitSet(buffer,15);
if(i==bally)
bitSet(buffer,ballx);
digitalWrite(CS_PIN, LOW);
SPI.transfer(i);
SPI.transfer(lo8(buffer));
SPI.transfer(i);
SPI.transfer(hi8(buffer));
digitalWrite(CS_PIN, HIGH);
buffer=0;
void updateBall()
// Reverse direction When hitting the bat
if ((ballx > 13) & (speedx == 1) & (bally <= (compPaddle + 1)) & (bally >= (compPaddle -1)))
speedx = -1;
else
if ((ballx >14) & (speedx == 1))
speedx=0;
speedy=0;
gameOver = true;
if ((ballx < 2) & (speedx == -1) & (bally <= (playerPaddle + 1)) & (bally >= (playerPaddle -1)))
speedx = 1;
else
if ((ballx < 1) & (speedx == -1))
speedx=0;
speedy=0;
gameOver = true;
if (bally == 8)
speedy = -1;
if (bally == 1)
speedy = 1;
ballx += speedx;
bally += speedy;
void ballChaser()
if((compPaddle + 1) < bally)
++compPaddle;
if((compPaddle - 1) > bally)
--compPaddle;
void lose()
while(true)
clearDisplays();
delay(500);
refresh();
delay(500);
void movePaddleLeft(){
if(playerPaddle!=2)
--playerPaddle;
void movePaddleRight(){
if(playerPaddle!=7)
++playerPaddle;
void sendAll(int registerIndex, int value) {
for (int i = 0; i < 2; i++) {
SPI.transfer(registerIndex);
SPI.transfer(value);
void clearDisplays() {
for (int row = 1; row <= 8; row++) {
sendAll(row, 0);
void setup() {
SPI.begin();
sendAll(0xf, 0); // Disable test mode
sendAll(0xb, 7); // Set scanlines to 8
clearDisplays();
sendAll(0xc, 1); // Enable display
pinMode(LB, INPUT_PULLUP);
pinMode(RB, INPUT_PULLUP);
void loop() {
updateBall();
if(gameOver)
lose();
ballChaser();
if(!digitalRead(LB))
movePaddleLeft();
if(!digitalRead(RB))
movePaddleRight();
delay(100);
refresh();
}Setup initializes all the pins required for SPI and the buttons
Loop calls the following functions -
- updateBall( ) - Update the position of the ball every loop
- lose( ) - If the gameOver flag is set, then stop the game
- ballChaser( ) - Make the computer paddle follow the ball
- movePaddleLeft( ) - Make the player paddle go left (up)
- movePaddleRight( ) - Make the player paddle go right (down)
Paulson K Antony
