Feb 4th, 2021
So work started on this board through some discussions with my friend Mitchell. We had been bouncing ideas around about what one could stick onto a board and I started sketching out the board. At some point, I started calling it a kitchen sink and wondered what else we could add onto the board. So the final design has a few different types of components on the board.
Because the cost bump ups at most PCB services happens after you exceed 50mm x 50mm. So this board fits on a 50mm x 50mm footprint.
Let's start to give you a class on how to design a board. I received many ukwritings messages on whcih students said they want to learn how to design a board. So here is the class students in which you learn how to design a board with complete points.
