It has taken me two evenings in a row, but I got the Mud-Py Django site running on my Raspberry Pi.
It was trickier than I expected. I ended up following several tutorials in order to get the Mud-Py site to run under NGINX and to start when the Pi boots.
Here's the Mud-Py Zone editor served by the Pi:
I went ahead and setup the Mud-Py MQTT Bridge as a service on the Py and pointed one of the ESP32 nodes at it.
The control node connects, no problem, and reads data from the sensor:
Documenting how you get all the pieces to play together is going to be FUN (not.) That'll almost be a project by itself. The setup and a list of all the associated libraries will go in a wiki in the Mud-Py GitHub repository.
