I did a little work on the Mud-Py Analyser this evening, adding in a synchronized "secondary zone view" so that I can compare data from two sensor types at once.
I especially wanted to be able to view soil moisture and temperature at the same time.
The video below is a comparison of soil moisture and temperature for the last 20 days.
There's some surprises in there, at least for me.
I expected something simple like "hotter = dryer."
It ain't so.
It turns out that there's significant changes in soil moisture during the night time. There are times when it is cool at night, and the soil moisture just drops only to climb again.
This is the kind of thing I expected:
That's a warm afternoon with temperatures above 25 degrees C (heading for 80 degree F.) The soil moisture dropped drastically in the areas I would expect it to. The lower edge is the street, and the right edge is the driveway - the street and the driveway both have deep layers of crushed rock that don't hold moisture at all.
What I didn't expect was this:
Compared to this:
The second image is at 4 o'clock in the morning, with temperatures around 5 degrees C.
The soil moisture has dropped over the entire yard compared to the previous evening, and that lower left corner is practically dried out.
If you scrub through the video, you'll find that the soil moisture has a quite active "night life." Things change a very good bit at times when I'd expect them to settle down.
I looked at some of the individual sensors while I was at it.
Some do only change slowly, like I'd expect.
Like this one:
Then there are ones that just yo-yo up and down all the time:
The sensor batteries seem to be recovering some now that things are warming up. Yesterday and today were fairly warm, and the battery capacities have risen again:
Cold increases the internal resistance of the coin cells which makes the sensor think the battery is losing capacity. As they warm up again, the internal resistance of the cells drops and the sensor duly reports a higher capacity.
The lithium cells in the power banks for the control nodes (the ESP32S modules) don't seem to be bothered by the cold:
I'll see about implementing dual views for the individual sensors, and see what that can tell me.
