Log 1
03/03/2021 at 01:09 • 0 commentsI have the first revision of my PCB design fabricated and I've populated enough of the board to read from 1 channel. A 1000 sample recording is shown below:
I'm not sure I have the conversion correct, but ~10-20 microvolts of input referred noise seems reasonable.
I'm currently running a build of micropython with ulab on the esp32, and that's been really useful for debugging communication. The code I ran to acquire the above data is below. I'll probably try to record some actual biopotentials (EMG/ECG before sticking it to my head), and then I'll start debugging the impedance measurement circuit. I'll probably start out using the Ultracortex Mark III headset design from openbci, but ultimately I want to explore other headset designs.
from machine import SPI,Pin DEV_ADD = 0x40 MCP_READ = 0x01 MCP_WRITE = 0x00 STATUSCOM = 0x18 CHAN_0 = 0x00 CHAN_1 = 0x02 CHAN_2 = 0x04 CHAN_3 = 0x06 GAIN = 0x16 CON0 = 0x1A CON1 = 0x1C r_gain=bytearray(1) w_gain=bytearray(1) r_statcom=bytearray(1) w_statcom=bytearray(1) r_con0=bytearray(1) w_con0=bytearray(1) r_con1=bytearray(1) w_con1=bytearray(1) r_0=bytearray(1) r_1=bytearray(1) r_2=bytearray(1) r_3=bytearray(1) r_gain[0]= DEV_ADD | GAIN | MCP_READ w_gain[0]= DEV_ADD | GAIN | MCP_WRITE r_statcom[0]=DEV_ADD | STATUSCOM | MCP_READ w_statcom[0]=DEV_ADD | STATUSCOM | MCP_WRITE r_con0[0]= DEV_ADD | CON0 | MCP_READ w_con0[0]= DEV_ADD | CON0 | MCP_WRITE r_con1[0]= DEV_ADD | CON1 | MCP_READ w_con1[0]= DEV_ADD | CON1 | MCP_WRITE r_0[0]=DEV_ADD | CHAN_0 | MCP_READ r_1[0]=DEV_ADD | CHAN_1 | MCP_READ r_2[0]=DEV_ADD | CHAN_2 | MCP_READ r_3[0]=DEV_ADD | CHAN_3 | MCP_READ MCP_SPI=SPI(1, 10000000, sck=Pin(14), mosi=Pin(13), miso=Pin(12)) MCP_SPI.init() MCP_SS=Pin(27,Pin.OUT) MCP_DRDY=Pin(26,Pin.IN) DRDY=False def callback(p): global DRDY DRDY=True MCP_DRDY.irq(trigger=Pin.IRQ_FALLING, handler=callback) statcom = 0xB9000F config0 = 0x3C0050 config1 = 0x0F0000 #channels off config1 = 0x000000 #channels on #read 24-bit value MCP_SS.value(0) MCP_SPI.write(r_3) #register address you want to read from MCP_SPI.read(3) MCP_SS.value(1) #write 24-bit value MCP_SS.value(0) MCP_SPI.write(w_statcom) #register address you want to write to MCP_SPI.write(b'\xB9') #data to write MSB MCP_SPI.write(b'\x00') #data to write MCP_SPI.write(b'\x0F') #data to write MCP_SS.value(1) #read some number of samples to a data array data=bytearray(3000) tmp=bytearray(3) i=1 point=0 while i<1001: if DRDY: MCP_SS.value(0) MCP_SPI.write(r_3) MCP_SPI.readinto(tmp) MCP_SS.value(1) data[point:point+3]=tmp i+=1 point=(i-1)*3 DRDY=0 #save the data to a file on the ESP32 f=open('data.txt') f=open('data.txt','w') f.write(data) f.close()
