I made this tutorial to guide you step by step while making this kind of super amazing low-cost electronic project which is the "Bluetooth Trolley Speaker". During the making of this project, we tried to make sure that this instructable will be the best guide for you in order to help you if you want to make your own Bluetooth Trolley Speaker, so we hope that this instructable contains the needed documents.
