Thanks to a tricky couple of years I have not been able to continue work on this. Thankfully things are becoming a little more stable now and I finally have a little time to dust off and complete this project.
I need to update the design to include my handmade fixes, correct the switch orientation to bring it into line with the original board.
At the same time, I need to check that the components are all still available and if not, find replacements.
KiCad has also at least one major release so I may need to tweak the project files to match.
My time is still limited so this will be slow but I am determined to get a v1.0 out of the gate and wrap up this project. Watch this space!
