What this firmware can do for you:
- Tracks all discovered ble devices or only the desired devices placed in a white-list
- Selectively reads the battery level of tracked devices
- Generates MQTT topic for an easy integration in you favorite Home Automation Hub
- Mimics a lepresenced server to be integrated in FHEM
- You can configure the devices to be tracked directly from the integrated WebServer without need to re-flash the firmware
- Supports for OTA Update
- Logs main events in order to identify problems.
MARIO D'AMICO
David Chatting
ELSHNKHLL
Patrice Freydiere
Released v3.4
This release comes with minor fixes:
- Reduced the number of reported connection error when the tracker tries to read the battery level of the device and log level is info
- Avoid to set the Transfer-Encoding header twice when the data is sent to the browser
