I have a generic cheap set of plastic RPG dice which I hope to use as a reference for my larger laser cut versions. The plan is to quantify some form of relative scaling/size.
Dice measurements in mm to one decimal place Dice | Edge length | Height | Height % (Based on D20) -----|-------------|--------|--------- D4 | 20.2 | 17 | 85 D6 | 16.2 | 16.2 | 81 D8 | 18.8 | 15.9 | 79.5 D10 | 15.9 7.2 | 15.9 | 79.5 D12 | 8.2 | 17.9 | 89.5 D20 | 12 | 20 | 100
The D20 is 20mm tall <3
Sproket
