First measurements
A project log for DC High Power Logger on the Cheap
A simple and low cost solution for logging power usage in a solar powered battery charger. Can be used for any high power DC system.
isaxiSax 03/10/2021 at 13:330 Comments
I've done a measurement on an almost full battery pack. This charge is from 96% to full. It worked nicely as shown in the plots below. I've now installed it with the fishermen that uses the charger and will return to collect the data after a week or so. The power and energy is calculated from the measured current and voltage. The noise on the current is from me putting zip ties on and fiddling with the Arduino while measuring.
Rich text editor
