A project log for Forced air HVAC Smart Pseudo-Zoning
Overcome temperature imbalances in homes with forced air built before modern HVAC design using a variable speed booster fan.
I've attached a link to my current schematic here which I've also uploaded to the project.
Additionally here is the interface schematic for the fan.
I am using the H11AA1 optoisolator on the 24VAC lines and also using another one (out of convenience) to drive the PWM signal for the 10v fan control line. The schematic does not show an optoisolator on the tach feedback circuit and I believe I need to add one as once this connection is made, the board stops working. Looking at my old test boards, I realized that the grounds were tied together between the fan and the Arduino. Attempting that now seems to lock the board up and it seems more straightforward to add more isolation. Not sure how it worked last time. Perhaps I just got lucky. I have been using the same part number as I use for the AC lines out of convenience but should swap this to a DC component. Additionally to conserve board space, I'd like to get select a multi-channel component for this. Still through hole because I'm not set up or skilled enough for surface mount.
So that's Goal #1 for the next revision: Fully isolate fan circuit with proper dual channel DC optoisolator component.
Yes, delete it Cancel
