Programming
I use the ESP-Prog development board as ordered on AliExpress (was €10.22).
using a serial connection
Connect the ESP32-mini module with ESP-Prog using the 6pin IDC-cable.
platformio.ini:
[env:nodemcu-32s]
platform = espressif32
board = nodemcu-32s
framework = arduino
monitor_port = /dev/ttyUSB1
monitor_speed = 115200
;Serial firmware upload
upload_port = /dev/ttyUSB1
This is the usual way of programming your ESP32. Make sure to put the jumper on IO0_ON/OFF on the ESP-Prog.
Programming works flawlessly.
using a JTAG connection
Uploading code using JTAG is many times slower than through the serial connection.
- Connect the ESP32-mini module with ESP-Prog using the 10pin IDC-cable.
- Power cycle the ESP32.
Don't use the "PlatformIO:Build" ✓-button on the bottom of VSCode screen, but use Run→Start Debugging (F5) to debug your project.
platformio.ini:
[env:nodemcu-32s]
board = nodemcu-32s
framework = arduino
;JTAG firmware upload and debug
upload_protocol = esp-prog
debug_tool = esp-prog
debug_init_break = tbreak setup
Uploading code and debugging works as well. If you want a serial port, you'll have to connect the 6pin IDC-cable in addition to the 10pin IDC-cable.
Christoph Tack
