An arduino based product UPC allows you to manage the connection of your computer between usb powered device. You can control it remotely with serial communication software running on your system.
Designed by Onur Yilmaz and Yusuf Arabaci.
#Connection
Detect CH340 in ComPorts list.
Baud Rate is 9600. After serial communication setup, connects if you send "C" (connect), disconnects if you send "D" (disconnect).
