Hackaday.io Hackaday.io
Sign up Log in
OxiKit Oxygen Concentrator
High Flow Oxygen Concentrator 15 LPM at 90%+ Concentrated o2 https://oxikit.com
oxikitOxiKit
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
17.3k views
6 comments
804 followers
  • Description
  • Details
  • Files 30
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 6
View Gallery
Public Chat
17.3k
6
804
89
Team (3)
  • oxikitOxiKit
  • jennyJenny
  • pesazanpes.azan
Join this project's team
  • OxiKit Oxygen Concentrator
  • Oxikit Website
hardware
ongoing project
Oxygen concentrator
Related lists
Featured Projects
Featured Projects on Hackaday.io
This project was created on 03/20/2021 and last updated 5 years ago.
Description
24 LPM at 92% Concentration Milestone Reached with our Oxikit Project!
Oxikit is a collaboration effort with the help of 200+ volunteers known as the Pillar Tribe made up of Top Engineers, Fortune 100 executives, Chief Medical Directors, Scientists and innovative Entrepreneurs led to a rapid collaboration to bring the OxiKit to life.
KEEP ECONOMY OPEN
‣ 75% hospitalized patients recover with high flow concentrated Oxygen.
‣ Offload 50-75% of demand off the healthcare system
‣ Send concentrators to patients' homes w/ remote Telehealth monitoring
‣ ROX algorithm to predict hours ahead to send critical patients to hospital
‣ Less deaths, catch them early- Less infected healthcare pros
‣ Easy to build designs even 16 year olds can assemble using common and locally found parts
Visit our website to learn more:
https://oxikit.com
Learn how to build your own Oxikit with video tutorials:
https://youtube.com/playlist?list=PL4O1
Details
Files
Portable Network Graphics (PNG) - 43.01 kB - 03/22/2021 at 02:53
Preview
OxyKit_v22.f3d
f3d - 7.33 MB - 03/20/2021 at 09:12
Download
Air Compressor WorkFlow.pdf
Adobe Portable Document Format - 880.71 kB - 03/20/2021 at 09:12
Preview
Frame WorkFlow.pdf
Adobe Portable Document Format - 1.02 MB - 03/20/2021 at 09:12
Preview
Orifices WorkFlow.pdf
Adobe Portable Document Format - 802.42 kB - 03/20/2021 at 09:12
Preview
View all 30 files
Log In/Sign up to comment
Sign up with Github
OR
abhimanyumalik wrote 06/08/2021 at 03:42 • point
heyaa
Michael wrote 05/05/2021 at 19:37 • point
I looked at the compressor and it appears to be a 120v 60hz unit. India and some of it's neighbors are 220v 50hz... I am not sure that it is a scroll.
pes.azan wrote 04/19/2021 at 09:50 • point
It's exciting to work on this project, I am adding few remote capabilities to the system to monitor and control certain parameters and introduce some automation into the sytem
excitedbox wrote 03/24/2021 at 09:27 • point
It is a diaphragm compressor. They are oil less. It is like a 2 cylinder engine but instead of pistons it has a rubber disc that is used to pump the air. That is also why you don't need oil, because the rubber disc is just pumped up and down instead of moving.
Dan Maloney wrote 03/22/2021 at 17:48 • point
Wow, I didn't expect so much enrichment at such a high flow! What kind of compressor is that? I'd imagine it would need to be oil-less -- perhaps a scroll compressor?
pes.azan wrote 04/19/2021 at 09:51 • point
Hi Dan!
you may have look at the provided files, all the compressor spec are mentioned
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "OxiKit Oxygen Concentrator", please tell us the reason.
Send message
Remove Member
