Hackaday.io Hackaday.io
Sign up Log in
Stereo power amplifier
A Class D audio power amplifier,made with TPA3116.
roscaleroscale
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
8 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
131
0
8
5
Team (1)
  • roscaleroscale
Join this project's team
  • hack amp
hardware
completed project
power amplifier tpa3116 CLASS D
Related lists
ODFAS - amplifiers
DIY (open source ?) amplifiers projects
This project was created on 03/23/2021 and last updated 5 years ago.
Description
I designed and built an audio power amplifier to power my two bookshelf speakers, which I think worked well.What I am using is D class power amplifier scheme, with TPA3116 power amplifier chip, can reach stereo 50W.I did it using KiCad, and now I've fully open sourced the project. I hope it will be helpful to you.
Details
Log In/Sign up to comment
Sign up with Github
OR
Building a Bench Lab Power Supply using an ATX Power Supply from a PC
Project Owner Contributor
ATX Bench Lab Power Supply
orlando-zenOrlando Zen
A simple combination 3.3v and 5v power supply.
Power Pod
jon-thomassonJon Thomasson
This is an audio Class-D power amplifier prototype. It is build in bridge mode and can give arround 500W.
Class-D Power Amplifier -prototype-
jairoJairo
Turn discarded (old) laptop power brick into bench variable DC power supply.
Power supply from discarded laptop adapter.
sudarshan-patilSudarshan patil
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Stereo power amplifier", please tell us the reason.
Send message
Remove Member
