Falstad
Run the Falstad simulation here: https://tinyurl.com/yhqfvbpn
LTspice
To run the simulation in LTspice, you'll need to download the CD4000.zip
file under the project documents and install the model libraries and symbols before downloading and opening hexo.asc
* /Documents/LTspice/Hexo.asc XU1 0 N003 N006 +V NC_01 N003 N003 +V NE555 V1 +V 0 9 R1 0 N003 4.7Meg C1 N003 0 100n IC=0 R2 N003 N005 10K Q1 N005 N002 +V 0 BC557C R3 N002 +V 3.3Meg R4 N001 N002 10Meg S1 0 N001 N004 0 SW V2 N004 0 PULSE(0 1 0.5 0 0 0.1 0 1) XU2 0 0 N006 N007 N009 N010 N011 N012 N013 N014 N015 N016 N017 0 VDD 0 CD4017B VDD=3.7 SPEED=1.0 TRIPDT=5e-9 D1 N007 N008 QTLP690C D2 N009 N008 QTLP690C D3 N010 N008 QTLP690C D4 N011 N008 QTLP690C D5 N012 N008 QTLP690C D6 N013 N008 QTLP690C D7 N014 N008 QTLP690C D8 N015 N008 QTLP690C D9 N016 N008 QTLP690C D10 N017 N008 QTLP690C R5 0 N008 4.7Meg C3 +V N001 1µ IC=0 .model D D .lib /Library/Application Support/LTspice/lib/cmp/standard.dio .model NPN NPN .model PNP PNP .lib /Library/Application Support/LTspice/lib/cmp/standard.bjt .tran 0 15 0 .model SW SW(Ron=1 Roff=1000G Vt=0.1 Vh=0) .include CD4000.lib .lib NE555.sub .backanno .end
