Features & Specifications
- Arduino UNO R3 / Adafruit Metro compatible form factor (3.3 V logic, may not be compatible with all Shields)
- PCI-e through M.2 B-Key connector on the rear of the board with dedicated 3.3 V / 3 A supply
- Analog to Digital Converter (MCP3008)
- On-the-fly switching between USB host (USB Type-A) and device mode (USB Type-C)
- Qwiic/Stemma QT connector to easily interface with I²C devices
- A full-sized camera connector that supports all Pi-compatible cameras
- A full-sized HDMI 2.0 port
- A WS2812 Smart RGB LED for user status
- Optional Wi-Fi or eMMC options depending on your choice of CM4
- Slim design with the Piunora Lite measuring 8-12 mm and the Piunora Pro measuring 11-13 mm
- Two user-controllable buttons (including software that turns one of them into a safe-shutdown button)
timonsku
Poyu Chen
pkElectronics
teardownit
tobychui
