I knew actuating the arm in the order XZE had limitations. For fun I did a brute force test in Unity and found that it was much worse than I realized. So I decided to push the Z axis first. Actually I don't know why I didn't do it this way sooner. It actually comes out really good. In the video I try to give a detailed explanation of the the ZXE arms.
