Here is the HTML for the project...
Please see:
https://sciencedude1990.github.io/hello_world_tests/scroll_test.html
I was learning javascript, so wanted to make a teleprompter webpage.
Please see:
<html>
<head>
<title>Scroll Test</title>
</head>
<body>
<script>
// State for the play/stop button
// 0 for stop, 1 for just started playing, 2 for playing
var state = 0;
// Speed for scrolling
var speed = 1;
// Variable for tracking scroll position, with fine granularity
var trackScroll = 0;
// Variable to hold the interval (for periodic update every 80 ms)
var myinterval = setInterval(updateDisplayArea, 80);
function updateDisplayArea() {
if (state == 1) {
// User just pressed the play button
// Set the scroll bar in the textarea to 0
var txtArea = document.getElementById("theText");
trackScroll = txtArea.scrollTop * 20;
// Set the state to 2
state = 2;
else if (state == 2) {
// Now playing...
var scrollRange = txtArea.scrollHeight - txtArea.offsetHeight;
// Only adjust the scroll bar if there is enough text
if (scrollRange > 0) {
// Increment the variable
trackScroll = trackScroll + speed;
// Divide by 20 and round
var temp = Math.round(trackScroll / 20);
// If the value in temp is less than the maximum scroll
if (temp <= scrollRange) {
txtArea.scrollTop = temp;
else {
// Back to stop
state = 0;
else {
// Back to stop
state = 0;
else if (state == 0) {
// State is stop, so make sure the button says play
var temp = document.getElementById("btnPlay");
temp.innerHTML = "Play";
// Update the label to indicate the speed
var temp = document.getElementById("btnSpeed");
temp.innerHTML = speed;
// Copy the text from the source to the teleprompter
function mrCopy() {
var txtSource = document.getElementById("theSource");
txtArea.value = txtSource.value;
// Call to change the state of the play button
function mrPlay() {
if (state == 0) {
state = 1;
temp.innerHTML = "Stop";
else {
state = 0;
// Call to change the speed
function mrSpeed(dir) {
if ((speed + dir) < 0) {
speed = 0;
else {
speed = speed + dir;
// window.alert("Speed: " + speed);
</script>
<textarea id="theText" name="theText" rows="16" cols="50" spellcheck="false" style="transform:scaleX(-1); transform:scaleY(-1); background-color:black; color:white; font-size:200%; text-align:center">
Hi!
</textarea>
<br>
<button id="btnPlay" style="font-size : 20px" onmouseup="mrPlay()">Play</button>
<button id="btnSpeedUp" style="font-size : 20px" onmouseup="mrSpeed(+1)"> + </button>
<button id="btnSpeedDown" style="font-size : 20px" onmouseup="mrSpeed(-1)"> - </button>
<button id="btnSpeed" style="font-size : 20px"> 1 </button>
<button id="btnCopy" style="font-size : 20px" onmouseup="mrCopy()">Copy</button>
<br>
<textarea id="theSource" name="theSource" rows="16" cols="50" style="font-size:200%">
Test test
</textarea>
<br>
</body>
</html>
