Hackaday.io Hackaday.io
Sign up Log in
High Voltage Regulated Power Supply
Geiger–Müller Tubes and Photomultipliers Tubes operate at voltages between 300v to 900v but also need to be regulated and low noise,
robert-hartRobert Hart
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.9k views
2 comments
46 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
1.9k
2
46
9
Team (1)
  • robert-hartRobert Hart
Join this project's team
completed project
This project was created on 07/06/2014 and last updated 11 years ago.
Description
I've built a few different power supplies for Geiger–Müller Tubes and Photomultipliers Tubes and this one has been the most reliable. http://www.hardhack.org.au/hv_reg_power
The circuit is based around a cheap CCFL inverter module and the common LM2576 3 Amp Adjustable Switchmode Regulator which can be bought over the counter at many electronics stores. The output of the inverter is rectified and filtered and and then feed back into the feedback of pin 4 on the LM2576 through a voltage divider. The output of the LM2576 is then used to supply of the inverter.
The LM2576 maybe seem like over-kill but my aim is to be both accessible and cost effective, and although there are better chips available unless your building a few hundred of these, it would be harder to choose a cheaper and more accessible alternative.
Details
Log In/Sign up to comment
Sign up with Github
OR
Robert Hart wrote 09/22/2015 at 21:20 • point
Hi HC I've used this design for over 10 years on many project, most were built from junk box parts on vero board, it's low noise and quite stable. Its to power high impedance loads such as Geiger, proportional or photomultiplier tubes  e.g. #Cosmic Ray (Muon) 81 (9x9) Pixel Hodoscope.  No doubt it could be improved, please feel free to redesign it as well as my other projects are open source and build for recreation, not production.  More details are on my website http://www.hardhack.org.au/hv_reg_power
K.C. Lee wrote 09/22/2015 at 12:51 • point
For high voltage caps in series, the usual advice is to have them connect across voltage balancing resistors.  Some people advice the same for rectifiers too.  Also note that regular resistors not rated for high voltages can have non-linearity.
The 2017 Hackaday Prize
Small form factor 2 x 7W Hi-Fi stereo amplifier, built from discrete parts
Project Owner Contributor
Mini Hi-Fi Power Amplifier
szoftveresSzoftveres
Power supplies are the basic components that provide the correct voltage and current required for the operation of electronic devices.
Power Supply V 1.0
hamza-deniz-ylmazHamza Deniz Yılmaz
A nice little tube amplifier that is low voltage but still has enough power to drive a speaker at a reasonable volume
Low Voltage All-Tube Amplifier
marcelMarcel
The requirement of stable DC power supplies in the IOT applications and in electronics designed products is very versatile.
Smallest 220V to 5V Supply for IOT applications
sagar-001Sagar 001
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "High Voltage Regulated Power Supply", please tell us the reason.
Send message
Remove Member
