There are two of our PCBs. They have XT60 connector inputs for battery and XT60 outputs to power sensors or other kind of stuffs on our UAVs. Every output connection getting power from Li-Po battery and regulate this for desired value. By using resistors we adjust the out voltage. Both of the boards for our UAVs and for regulate power.
This card is designed for unmanned ground vehicle (UGV) and is capable of meeting the power requirements of the onboard sensors and autopilot. There is also a motor drive system that will enable the UAG to move.
Christoph
Sudarshan patil
Krzysztof Wrzalka
