To be able to mount the printhead onto a lightweight machine frame like a 3D printer I had to remove the heavy armored cord which protects the cables and tubing connected to the printhead.
For doing this I had to disconnect all tubing and cables from the printhead, remove the cables and reconnect them.
Not much to say:
- It worked
- It was a big mess
- I needed almost 100 zip ties
- I had to clean my room afterwards
- It was worth it :)
![](https://cdn.hackaday.io/images/274071617563856308.jpg)
![](https://cdn.hackaday.io/images/7114841617563897158.jpg)
![](https://cdn.hackaday.io/images/2651661617563993931.jpg)
