I replaced the 5/2 way solenoid valve for the ink pressure with two 2/2 way solenoid valves - one for switching the pressure and one for venting - so that all valves that switch air are from the same type. I also added mufflers to the venting valves for ink and pump pressure. Both the ink and pump pressure function switch a relay that has two valves connected to it - one for switching the pressure when the function gets activated and one for venting the lines when the function gets deactivated.
![](https://cdn.hackaday.io/images/1330021666630694276.jpg)
The ink filter is now mounted on the frame again.
![](https://cdn.hackaday.io/images/5691361666630722710.jpg)
And the check valves are now directly connected to the nozzle and return port.
![](https://cdn.hackaday.io/images/7636591666630753171.jpg)
