Prototype 1 has been done for a while, though the projection screen was at a 45° angle, which was suboptimal and would get in the way easily. Also, the screen holder had a 2mm slot, and the sheet of acrylic I use is 1mm thick, because I originally planned on using a 2mm acrylic sheet, but I found a cheaper 1mm sheet on AliExpress.
![Prototype 1 Prototype 1](https://cdn.hackaday.io/images/8065031618752748837.jpg)
