Prototype 1!
A project log for GLASSES
Custom HUD Smartglasses, made by OmegaVoid
omegarogueOmegaRogue • 04/18/2021 at 13:37•0 Comments
Prototype 1 has been done for a while, though the projection screen was at a 45° angle, which was suboptimal and would get in the way easily. Also, the screen holder had a 2mm slot, and the sheet of acrylic I use is 1mm thick, because I originally planned on using a 2mm acrylic sheet, but I found a cheaper 1mm sheet on AliExpress.
Prototype 1
Prototype 1, attached to a set of cinema 3d glasses for testing.
