Be carefull, if you reduce the spacer of the display board to the tube board. Attention not to break the glass-seal.
A project log for MC6205/MS6205 | ESP32 Weatherstation, NTP Clock
Weatherstation based on MC6205 (MS6205) russian gas discharge (Plasma) display using ESP32
