Identify the need, list of goals & hacked together a proof-of-concept as per the details section.
Wrote (first generation) of software using WebSockets for good a selection of pulse patterns. All OK.
Read lots about submitting to PCB prototyping companies. Settled on KiCAD, with the simplest viable THT design to improve chances of success. First 3 boards were perfect first time. Assembled in 3 variations: mechanical relay, opto-isolator & off-board SSR (will add onboard inline PCB SSR when I find it). Only have a few little SMT regulators to hand to soldered on legs & a heat-sink. All pics are of these first boards.
Test in every configuration with both "ESP-01" & "ESP-1 S". Tweak a couple of component values. All OK but identified a few opportunities to improve layout - particularly for mains traces. Start the feature-creep! Add MOSFET option. Add edge castellations for direct Fotek SSD mount. Test with 1-Wire DS18B20 - no additional components needed. Update PCB design for next version including looking at how to mix THT & SMT for assembled or kit options. Look at BoM management & component sourcing,
Start planning new software architecture to support multiple concurrent control streams.
Outline software for special cases using teamed boards.
ToDo:
Finish combined THT/SMT PCB design & get new boards made & assembled. Q: How many?
Finish second generation software - no hurry as gen1 does what I need & still better than any other.
