The UWB base station can be used to achieve precise ranging of point to point or
point to multi-point, or multi-point to multi-point, and to measure the real-time relative
distance between objects. The ranging precision is as much as 10 cm, and the effective
ranging distance is more than 500 meters. Please connect zyc@huaxingzhikong.com, if you are interested. Company website: http://www.huaxingzhikong.com/
