DIY 3D printable 40% ortholinear keyboard.
Originally made using kbfirmware.com, but has since been ported over to full QMK, and now with VIAL GUI Configurator support.
I mostly made this just to see if a could since I had all the parts on hand. Next I'd like to make a split tented keyboard similar to the orthodex, but with the Cirque capacitive trackpads added.
But for now I'm happy with this design.
Firmware, Freecad project, and stl's attached.
- Initial layout generated in http://www.keyboard-layout-editor.com
- Data from KLE used to generate plate svg in https://kbplate.ai03.com and imported to FreeCAD.
- Plate and housing made in FreeCAD.
- Used the QMK Source/Environment to generate a new QMK firmware
- Then used that to port it to VIAL to work with the VIAL GUI Configurator.
- Extract attached zipfile just goes in the VIAL keyboard folder in their source to generate new firmware or use as an example for your own.
Ticktok
