Cubify Cube 3D printer
Table of Contents
The Cubify Cube 3d printer is a plastic filament 3D-printer. It's production is discontinued but I got mine for free from one of the members of the Warsaw Hackerspace so I thought I might as well see what's it worth. The online reviews of this printer are pretty bad (it has > 50% 1-star reviews on Amazon) but hey, I got it for free together with two cartridges of filament.
Screws are Allen H2.5 not Allen H3 or Torx like I thought.
1 Main board
1.1 Chips
Item | Type | Notes |
Microcontroller | PIC32MX450F256H | |
WLAN chip | RN131C//RM | |
VN5050J | Automotive driver, purpose unknown | |
Stepper motor drivers | A3979 | 4 x stepper motor drivers. Makes sense, the 3d printer has 4 stepper motors (3 axes and extruder). |
LCD | https://www.docdroid.net/JLZDTjm/pt0242432t-c402-j-vera.pdf#page=11 | |
OTG transciever | For both host (usb sticks) and device (back connector for firmware programming). |
1.2 Connectors
There are the following connectors on the board:
- a PICkit2 connector (unpopulated)
- a CONN12 connector (unpopulated)
- a microSD (TransFlash) connector (populated with a 4 GB card). It is likely used to store the print gcode files and settings
- a twopin cartridge plug-in detect connector. Connected to the PIC pin 63 RPE3/CTPLS/PMD3/RE3
- spring pins connecting to a chip inside the cartridge via 1-Wire, connected to the PIC pin SDA2/U2RX/PMA9/CN17/RF4
1.3 Tapping the PIC <-> WLAN communications
I soldered two new pin headers onto the board to access the PICkit2 connector as well as the CONN12 which I expected would be the serial port. My suspicions were correct, when plugging in a USB<->RS232 adapter I started seeing some interesting output. This is actually the interface between the PIC microprocessor and the WLAN module.
Here is what can be seen on the console when the Cube is powered on:
# picocom -b 57600 /dev/ttyUSB0 picocom v2.2 port is : /dev/ttyUSB0 flowcontrol : none baudrate is : 57600 parity is : none databits are : 8 stopbits are : 1 escape is : C-a local echo is : no noinit is : no noreset is : no nolock is : no send_cmd is : sz -vv receive_cmd is : rz -vv -E imap is : omap is : emap is : crcrlf,delbs, Type [C-a] [C-h] to see available commands Terminal ready 0.000 Cube V2.07 0.000 Baud:227272
Later after the button is pressed and the GUI starts:
2.000 $$$ 2.200 D_LOAD_SETTINGS_FILE_CHECK_FS 2.200 D_LOAD_SETTINGS_FILE_CHECK_FILE 2.200 D_LOAD_SETTINGS_FILE_AND_RENAME 2.200 D_WRITE_NVM CMD 2.200 set u m 0x31 AOK 2.225 set w l 5 AOK 2.225 save Storing in config 2.225 get mac Mac Addr=00:06:66:21:f1:46 2.250 ver wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131 2.250 exit EXIT
Each message has a timestamp in it's header which is like sysUpTime in that it counts time since boot. Some more interesting strings are produced when a WiFi scan is triggered:
126.550 $$$ CMD 126.600 set w j 0 AOK 126.625 save Storing in config 126.625 reboot *Reboot* 128.625 $$$ CMD 128.675 set sys printlvl 0x4000 AOK 128.700 scan SCAN:Found 4 01,06,-75,04,3104,28,40,xx:xx:xx:xx:xx:xx,ZyXEL XXXXXX v2 02,11,-39,04,1104,28,00,xx:xx:xx:xx:xx:xx,XXXXX 03,11,-84,04,3100,28,00,xx:xx:xx:xx:xx:xx,XXXXXXXXXX 04,11,-83,04,3100,28,00,xx:xx:xx:xx:xx:xx,XXXXXXXX 131.300 exit END: EXIT
The commands are documented on Microchip's site
Example WLAN association output:
525.150 $$$ CMD 525.325 set w j 0 AOK 525.350 save Storing in config 525.375 reboot *Reboot* 527.375 $$$ CMD 527.425 set sys printlvl 0x4000 AOK 527.450 scan SCAN:Found 6 01,01,-84,04,1105,28,40,xx:xx:xx:xx:xx:xx,XXXXXXXXX 02,08,-76,04,3104,28,40,xx:xx:xx:xx:xx:xx,XXXXXXXXXX 03,11,-40,04,1104,28,00,xx:xx:xx:xx:xx:xx,XXXXXXx 04,11,-78,04,3100,28,00,xx:xx:xx:xx:xx:xx,XXXX 05,11,-78,04,3100,28,00,xx:xx:xx:xx:xx:xx,XXXXXXXXX 06,11,-80,04,3100,28,00,xx:xx:xx:xx:xx:xx,XXX 530.075 exit END: EXIT 620.800 $$$ CMD 620.825 set i d 1 AOK 620.850 set w a 4 AOK 620.850 set w p XXXXX AOK 621.300 set w j 1 AOK 621.300 set w c 0 AOK 621.300 join XXXXX Auto-Assoc XXXXX chan=11 mode=MIXED SCAN OK Joining XXXX now.. Associated! DHCP: Start DHCP in 4789ms, lease=3600s IF=UP DHCP=ON IP=10.1.0.8:2000 NM=255.255.255.240 GW=10.1.0.1 626.625 save Listen on 2000 Storing in config 626.625 exit EXIT
2 Cartridges
The chip inside the cartridge with filament is a DS28E01.
3 Software
The software needed is the older Cubify not the new Cube Print. When trying to print the new files the printer displays a message "Cannot print this file".
4 CONN12 output while printing
Besides communication from the microcontroller to the WLAN chip the CONN12 serial port serves also as a debug console. I have wired an external cable reaching out of the case to watch what happens there. The pinout of this connector is the following:
PIN | +3.3 V | GND | TXD | RXD |
Ext. cable | purple | blue | green |
The serial port setup to receive data is 57600 bps 8n1. Here are some dumps from the printer doing printing-related stuff.
Debug output when printing and filament broke:
2.000 $$$ 2.200 D_LOAD_SETTINGS_FILE_CHECK_FS 2.200 D_LOAD_SETTINGS_FILE_CHECK_FILE CMD 2.750 set u m 0x31 AOK 2.775 set w l 5 AOK 2.775 save Storing in config 2.800 get mac Mac Addr=00:06:66:21:f1:46 2.825 ver wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131 2.825 exit EXIT 55.450 D_FILAMENT_LENGTH= 55.450 106590 55.450 TE4 RST E1 T=10 68.300 TE4 E1 T=125 DT=115 CR=2300 TH=225 73.275 TE4 E1 T=150 DT=25 CR=500 TH=225 78.250 TE4 E1 T=174 DT=24 CR=480 TH=200 83.225 TE4 E1 T=195 DT=21 CR=420 TH=200 88.200 TE4 E1 T=214 DT=19 CR=380 TH=175 96.950 Encoder=2.75mm ext=0mm 98.250 Encoder=5.51mm ext=3mm 100.250 Encoder=8.26mm ext=6mm 101.250 Encoder=11.01mm ext=8mm 103.200 Encoder=13.77mm ext=11mm 104.300 Encoder=16.52mm ext=13mm 106.150 Encoder=19.27mm ext=16mm 107.350 Encoder=22.02mm ext=18mm 109.450 Encoder=24.78mm ext=22mm 110.650 Encoder=27.53mm ext=24mm 112.800 Encoder=30.28mm ext=27mm 114.000 Encoder check, ext=30mm 114.100 Encoder=33.04mm ext=30mm 116.000 Encoder=35.79mm ext=33mm 117.300 Encoder=38.54mm ext=35mm 119.400 Encoder=41.30mm ext=39mm 120.350 Encoder=44.05mm ext=40mm 122.950 Encoder=46.80mm ext=44mm 124.050 Encoder=49.55mm ext=46mm 125.850 Encoder=52.31mm ext=49mm 127.100 Encoder=55.06mm ext=51mm 129.200 Encoder=57.81mm ext=54mm 130.400 Encoder=60.57mm ext=56mm 132.250 Encoder check, ext=60mm 132.500 Encoder=63.32mm ext=60mm 133.800 Encoder=66.07mm ext=62mm 134.200 Encoder=68.82mm ext=63mm 134.650 Encoder=71.58mm ext=63mm 136.350 Encoder=74.33mm ext=65mm 137.650 Encoder=77.08mm ext=68mm 139.700 Encoder=79.84mm ext=71mm 140.700 Encoder=82.59mm ext=73mm 142.600 Encoder=85.34mm ext=76mm 143.700 Encoder=88.10mm ext=78mm 145.500 Encoder=90.85mm ext=81mm 147.050 Encoder=93.60mm ext=83mm 149.100 Encoder=96.36mm ext=87mm 150.300 Encoder=99.11mm ext=89mm 150.700 Encoder check, ext=90mm 152.400 Encoder=101.86mm ext=92mm 153.750 Encoder=104.61mm ext=95mm 155.650 Encoder=107.37mm ext=98mm 156.950 Encoder=110.12mm ext=100mm 158.950 Encoder=112.87mm ext=104mm 160.000 Encoder=115.63mm ext=105mm 161.850 Encoder=118.38mm ext=109mm 162.950 Encoder=121.13mm ext=111mm 164.800 Encoder=123.88mm ext=114mm 165.950 Encoder=126.64mm ext=116mm 168.100 Encoder=129.39mm ext=119mm 168.200 Encoder check, ext=120mm 169.200 Encoder=132.14mm ext=121mm 172.100 Encoder=134.90mm ext=125mm 173.350 Encoder=137.65mm ext=127mm 175.950 Encoder=140.40mm ext=130mm 177.250 Encoder=143.16mm ext=133mm 179.400 Encoder=145.91mm ext=136mm 180.450 Encoder=148.66mm ext=138mm 182.450 Encoder=151.42mm ext=141mm 183.550 Encoder=154.17mm ext=143mm 185.550 Encoder=156.92mm ext=146mm 186.750 Encoder=159.67mm ext=148mm 187.650 Encoder check, ext=150mm 188.950 Encoder=162.43mm ext=152mm 190.150 Encoder=165.18mm ext=154mm 192.400 Encoder=167.93mm ext=157mm 193.750 Encoder=170.69mm ext=159mm 195.800 Encoder=173.44mm ext=163mm 197.950 Encoder=176.19mm ext=165mm 201.900 Encoder=178.95mm ext=169mm 211.500 Encoder check, ext=180mm 229.900 Encoder check, ext=210mm 229.900 D_FILAMENT_FLOW_STOPPED
Finished print of 20mm test cube (after filament replaced):
842.500 D_OW_NO_RESET_PRESENCE 872.500 TE4 RST E1 T=10 887.475 TE4 E1 T=130 DT=120 CR=2400 TH=225 892.450 TE4 E1 T=155 DT=25 CR=500 TH=225 897.425 TE4 E1 T=178 DT=23 CR=460 TH=200 902.400 TE4 E1 T=199 DT=21 CR=420 TH=200 907.375 TE4 E1 T=217 DT=18 CR=360 TH=175 912.350 TE4 E1 T=234 DT=17 CR=340 TH=175 1279.600 D_FILAMENT_LENGTH= 1279.600 106292 1279.600 TE4 RST E1 T=10 1291.550 TE4 E1 T=142 DT=132 CR=2640 TH=225 1296.525 TE4 E1 T=167 DT=25 CR=500 TH=200 1301.500 TE4 E1 T=189 DT=22 CR=440 TH=200 1306.475 TE4 E1 T=209 DT=20 CR=400 TH=200 1316.050 Encoder=2.75mm ext=0mm 1318.000 Encoder=5.51mm ext=3mm 1319.000 Encoder=8.26mm ext=5mm 1320.950 Encoder=11.01mm ext=8mm 1322.050 Encoder=13.77mm ext=10mm 1323.900 Encoder=16.52mm ext=13mm 1325.050 Encoder=19.27mm ext=15mm 1327.200 Encoder=22.02mm ext=19mm 1328.400 Encoder=24.78mm ext=21mm 1330.500 Encoder=27.53mm ext=24mm 1331.850 Encoder=30.28mm ext=27mm 1333.600 Encoder check, ext=30mm 1333.750 Encoder=33.04mm ext=30mm 1335.100 Encoder=35.79mm ext=32mm 1337.150 Encoder=38.54mm ext=36mm 1338.150 Encoder=41.30mm ext=37mm 1340.050 Encoder=44.05mm ext=41mm 1341.150 Encoder=46.80mm ext=42mm 1343.700 Encoder=49.55mm ext=46mm 1344.900 Encoder=52.31mm ext=48mm 1347.000 Encoder=55.06mm ext=51mm 1348.250 Encoder=57.81mm ext=53mm 1350.350 Encoder=60.57mm ext=57mm 1351.650 Encoder=63.32mm ext=59mm 1351.900 Encoder check, ext=60mm 1353.600 Encoder=66.07mm ext=62mm 1353.900 Encoder=68.82mm ext=63mm 1354.400 Encoder=71.58mm ext=63mm 1355.500 Encoder=74.33mm ext=65mm 1357.600 Encoder=77.08mm ext=68mm 1358.550 Encoder=79.84mm ext=70mm 1360.550 Encoder=82.59mm ext=73mm 1361.550 Encoder=85.34mm ext=75mm 1363.450 Encoder=88.10mm ext=78mm 1364.650 Encoder=90.85mm ext=80mm 1367.100 Encoder=93.60mm ext=84mm 1368.250 Encoder=96.36mm ext=86mm 1370.350 Encoder check, ext=90mm 1370.400 Encoder=99.11mm ext=90mm 1371.700 Encoder=101.86mm ext=92mm 1373.650 Encoder=104.61mm ext=95mm 1374.900 Encoder=107.37mm ext=97mm 1376.950 Encoder=110.12mm ext=101mm 1377.900 Encoder=112.87mm ext=102mm 1379.900 Encoder=115.63mm ext=106mm 1380.950 Encoder=118.38mm ext=108mm 1382.800 Encoder=121.13mm ext=111mm 1384.000 Encoder=123.88mm ext=113mm 1386.150 Encoder=126.64mm ext=117mm 1387.300 Encoder=129.39mm ext=119mm 1387.900 Encoder check, ext=120mm 1389.400 Encoder=132.14mm ext=122mm 1390.750 Encoder=134.90mm ext=124mm 1391.600 Encoder=137.65mm ext=125mm 1393.450 Encoder=140.40mm ext=128mm 1395.350 Encoder=143.16mm ext=130mm 1397.400 Encoder=145.91mm ext=133mm 1398.500 Encoder=148.66mm ext=135mm 1400.550 Encoder=151.42mm ext=138mm 1401.650 Encoder=154.17mm ext=140mm 1403.600 Encoder=156.92mm ext=143mm 1404.850 Encoder=159.67mm ext=145mm 1407.050 Encoder=162.43mm ext=149mm 1407.350 Encoder check, ext=150mm 1408.300 Encoder=165.18mm ext=151mm 1410.500 Encoder=167.93mm ext=155mm 1411.900 Encoder=170.69mm ext=157mm 1413.900 Encoder=173.44mm ext=160mm 1415.300 Encoder=176.19mm ext=163mm 1418.600 Encoder=178.95mm ext=166mm 1420.350 Encoder=181.70mm ext=168mm 1420.850 Encoder=184.45mm ext=168mm 1424.200 Encoder=187.20mm ext=171mm 1426.050 Encoder=189.96mm ext=173mm 1428.950 Encoder=192.71mm ext=176mm 1430.200 Encoder=195.46mm ext=178mm 1431.150 Encoder check, ext=180mm 1432.450 Encoder=198.22mm ext=182mm 1433.650 Encoder=200.97mm ext=184mm 1435.900 Encoder=203.72mm ext=187mm 1437.250 Encoder=206.48mm ext=190mm 1439.300 Encoder=209.23mm ext=193mm 1440.650 Encoder=211.98mm ext=195mm 1442.750 Encoder=214.73mm ext=198mm 1443.850 Encoder=217.49mm ext=200mm 1445.850 Encoder=220.24mm ext=204mm 1447.000 Encoder=222.99mm ext=205mm 1448.950 Encoder=225.75mm ext=209mm 1449.550 Encoder check, ext=210mm 1450.750 Encoder=228.50mm ext=211mm 1454.700 Encoder=231.25mm ext=214mm 1457.000 Encoder=234.01mm ext=216mm 1460.850 Encoder=236.76mm ext=220mm 1462.200 Encoder=239.51mm ext=222mm 1464.250 Encoder=242.26mm ext=225mm 1465.550 Encoder=245.02mm ext=228mm 1467.700 Encoder=247.77mm ext=231mm 1468.800 Encoder=250.52mm ext=233mm 1470.750 Encoder=253.28mm ext=236mm 1471.950 Encoder=256.03mm ext=238mm 1472.950 Encoder check, ext=240mm 1473.850 Encoder=258.78mm ext=241mm 1475.150 Encoder=261.54mm ext=243mm 1477.350 Encoder=264.29mm ext=247mm 1478.600 Encoder=267.04mm ext=249mm 1480.800 Encoder=269.79mm ext=252mm 1483.050 Encoder=272.55mm ext=255mm 1486.600 Encoder=275.30mm ext=258mm 1488.950 Encoder=278.05mm ext=260mm 1489.200 Encoder=280.81mm ext=260mm 1489.350 Encoder=283.56mm ext=260mm 1493.100 Encoder=286.31mm ext=264mm 1494.150 Encoder=289.07mm ext=265mm 1496.150 Encoder=291.82mm ext=269mm 1496.750 Encoder check, ext=270mm 1497.250 Encoder=294.57mm ext=270mm 1499.200 Encoder=297.32mm ext=274mm 1500.500 Encoder=300.08mm ext=276mm 1502.650 Encoder=302.83mm ext=279mm 1503.950 Encoder=305.58mm ext=281mm 1506.100 Encoder=308.34mm ext=285mm 1507.550 Encoder=311.09mm ext=287mm 1509.550 Encoder=313.84mm ext=290mm 1510.950 Encoder=316.60mm ext=293mm 1513.050 Encoder=319.35mm ext=296mm 1514.100 Encoder=322.10mm ext=298mm 1515.550 Encoder check, ext=300mm 1517.100 Encoder=324.85mm ext=301mm 1519.250 Encoder=327.61mm ext=303mm 1522.650 Encoder=330.36mm ext=306mm 1524.800 Encoder=333.11mm ext=308mm 1525.000 Encoder=335.87mm ext=308mm 1525.500 Encoder=338.62mm ext=308mm 1527.600 Encoder=341.37mm ext=312mm 1528.900 Encoder=344.13mm ext=314mm 1531.150 Encoder=346.88mm ext=318mm 1532.500 Encoder=349.63mm ext=320mm 1534.550 Encoder=352.38mm ext=323mm 1535.900 Encoder=355.14mm ext=325mm 1538.000 Encoder=357.89mm ext=329mm 1538.500 Encoder check, ext=330mm 1539.050 Encoder=360.64mm ext=330mm 1541.050 Encoder=363.40mm ext=334mm 1542.200 Encoder=366.15mm ext=336mm 1544.100 Encoder=368.90mm ext=339mm 1545.400 Encoder=371.66mm ext=341mm 1548.600 Encoder=374.41mm ext=344mm 1550.600 Encoder=377.16mm ext=346mm 1551.200 Encoder=379.91mm ext=347mm 1555.000 Encoder=382.67mm ext=350mm 1555.250 Encoder=385.42mm ext=350mm 1555.650 Encoder=388.17mm ext=350mm 1558.100 Encoder=390.93mm ext=352mm 1561.700 Encoder=393.68mm ext=356mm 1563.950 Encoder=396.43mm ext=358mm 1564.950 Encoder=399.19mm ext=358mm 1566.300 Encoder check, ext=360mm 1568.800 Encoder=401.94mm ext=361mm 1570.400 Encoder=404.69mm ext=363mm 1574.100 Encoder=407.44mm ext=366mm 1575.000 Encoder=410.20mm ext=367mm 1576.400 Encoder=412.95mm ext=368mm 1577.100 Encoder=415.70mm ext=368mm 1580.350 Encoder=418.46mm ext=371mm 1582.650 Encoder=421.21mm ext=373mm 1586.650 Encoder=423.96mm ext=377mm 1586.800 Encoder=426.72mm ext=377mm 1587.250 Encoder=429.47mm ext=377mm 1589.700 Encoder=432.22mm ext=379mm 1593.650 Encoder=434.97mm ext=382mm 1596.500 Encoder=437.73mm ext=385mm 1600.550 Encoder=440.48mm ext=388mm 1602.450 Encoder check, ext=390mm 1603.050 Encoder=443.23mm ext=390mm 1606.900 Encoder=445.99mm ext=393mm 1607.050 Encoder=448.74mm ext=394mm 1607.500 Encoder=451.49mm ext=394mm 1609.600 Encoder=454.25mm ext=395mm 1613.150 Encoder=457.00mm ext=399mm 1615.500 Encoder=459.75mm ext=400mm 1615.850 Encoder=462.50mm ext=401mm 1616.250 Encoder=465.26mm ext=401mm 1619.500 Encoder=468.01mm ext=403mm 1621.550 Encoder=470.76mm ext=406mm 1621.750 Encoder=473.52mm ext=406mm 1621.900 Encoder=476.27mm ext=406mm 1625.750 Encoder=479.02mm ext=409mm 1625.900 Encoder=481.77mm ext=409mm 1626.350 Encoder=484.53mm ext=409mm 1628.800 Encoder=487.28mm ext=411mm 1632.750 Encoder=490.03mm ext=415mm 1634.950 Encoder=492.79mm ext=417mm 1635.150 Encoder=495.54mm ext=417mm 1635.600 Encoder=498.29mm ext=417mm 1638.850 Encoder check, ext=420mm 1639.550 Encoder=501.05mm ext=420mm 1641.850 Encoder=503.80mm ext=422mm 1641.900 Encoder=506.55mm ext=422mm 1642.100 Encoder=509.30mm ext=422mm 1645.950 Encoder=512.06mm ext=426mm 1646.050 Encoder=514.81mm ext=426mm 1646.500 Encoder=517.56mm ext=426mm 1648.000 Encoder=520.32mm ext=428mm 1648.150 Encoder=523.07mm ext=428mm 1648.750 Encoder=525.82mm ext=428mm 1652.150 Encoder=528.58mm ext=431mm 1653.950 Encoder=531.33mm ext=433mm 1657.950 Encoder=534.08mm ext=436mm 1658.200 Encoder=536.84mm ext=436mm 1658.750 Encoder=539.59mm ext=436mm 1660.550 Encoder=542.34mm ext=438mm *ERR WATCHDOG: 6C24* 1664.500 Encoder=545.09mm ext=442mm 1667.000 Encoder=547.85mm ext=443mm 1671.450 Encoder=550.60mm ext=447mm 1673.850 Encoder=553.35mm ext=449mm 1674.050 Encoder check, ext=450mm 1678.000 Encoder=556.11mm ext=453mm 1678.850 Encoder=558.86mm ext=453mm 1680.750 Encoder=561.61mm ext=455mm 1684.550 Encoder=564.36mm ext=458mm 1686.900 Encoder=567.12mm ext=460mm 1690.850 Encoder=569.87mm ext=463mm 1692.950 Encoder=572.62mm ext=465mm 1696.850 Encoder=575.38mm ext=468mm 1699.450 Encoder=578.13mm ext=470mm 1703.350 Encoder=580.88mm ext=474mm 1705.350 Encoder=583.64mm ext=476mm 1705.500 Encoder=586.39mm ext=476mm 1705.950 Encoder=589.14mm ext=476mm 1710.400 Encoder=591.90mm ext=480mm 1710.400 Encoder check, ext=480mm 1712.850 Encoder=594.65mm ext=482mm 1717.000 Encoder=597.40mm ext=485mm 1719.750 Encoder=600.15mm ext=487mm 1723.500 Encoder=602.91mm ext=491mm 1725.150 Encoder=605.66mm ext=492mm 1726.050 Encoder=608.41mm ext=493mm 1729.700 Encoder=611.17mm ext=496mm 1731.650 Encoder=613.92mm ext=497mm 1735.050 Encoder=616.67mm ext=501mm 1737.550 Encoder=619.42mm ext=503mm 1738.250 Encoder=622.18mm ext=503mm 1742.000 Encoder=624.93mm ext=506mm 1742.500 Encoder=627.68mm ext=507mm 1742.600 Encoder=630.44mm ext=507mm 1744.350 Encoder=633.19mm ext=508mm 1745.600 Encoder check, ext=510mm 1748.650 Encoder=635.94mm ext=512mm 1748.750 Encoder=638.70mm ext=512mm 1749.300 Encoder=641.45mm ext=512mm 1751.600 Encoder=644.20mm ext=514mm 1755.150 Encoder=646.96mm ext=517mm 1757.800 Encoder=649.71mm ext=520mm 1758.000 Encoder=652.46mm ext=520mm 1758.450 Encoder=655.21mm ext=520mm 1762.150 Encoder=657.97mm ext=523mm 1762.800 Encoder=660.72mm ext=523mm 1764.200 Encoder=663.47mm ext=525mm 1767.900 Encoder=666.23mm ext=528mm 1768.100 Encoder=668.98mm ext=528mm 1768.500 Encoder=671.73mm ext=528mm 1770.700 Encoder=674.48mm ext=530mm 1774.150 Encoder=677.24mm ext=533mm 1776.650 Encoder=679.99mm ext=535mm 1777.350 Encoder=682.74mm ext=535mm 1781.150 Encoder=685.50mm ext=539mm 1782.100 Encoder check, ext=540mm 1783.450 Encoder=688.25mm ext=541mm 1787.750 Encoder=691.00mm ext=544mm 1790.700 Encoder=693.76mm ext=546mm 1794.300 Encoder=696.51mm ext=550mm 1796.950 Encoder=699.26mm ext=552mm 1797.050 Encoder=702.02mm ext=552mm 1797.500 Encoder=704.77mm ext=552mm 1801.300 Encoder=707.52mm ext=555mm 1803.350 Encoder=710.27mm ext=557mm 1807.050 Encoder=713.03mm ext=560mm 1807.150 Encoder=715.78mm ext=560mm 1807.600 Encoder=718.53mm ext=560mm 1809.200 Encoder=721.29mm ext=562mm 1809.250 Encoder=724.04mm ext=562mm 1809.850 Encoder=726.79mm ext=562mm 1813.050 Encoder=729.54mm ext=565mm 1813.100 Encoder=732.30mm ext=565mm 1813.300 Encoder=735.05mm ext=565mm 1815.400 Encoder=737.80mm ext=567mm 1818.050 Encoder check, ext=570mm 1820.350 Encoder=740.56mm ext=571mm 1822.350 Encoder=743.31mm ext=573mm 1826.300 Encoder=746.06mm ext=577mm 1826.550 Encoder=748.82mm ext=577mm 1827.000 Encoder=751.57mm ext=577mm 1829.300 Encoder=754.32mm ext=579mm 1829.500 Encoder=757.08mm ext=579mm 1830.050 Encoder=759.83mm ext=579mm 1833.200 Encoder=762.58mm ext=582mm 1833.300 Encoder=765.33mm ext=582mm 1833.500 Encoder=768.09mm ext=582mm 1835.700 Encoder=770.84mm ext=584mm 1840.500 Encoder=773.59mm ext=588mm 1842.250 Encoder=776.35mm ext=590mm 1845.850 Encoder=779.10mm ext=593mm 1848.300 Encoder=781.85mm ext=595mm 1852.200 Encoder=784.60mm ext=598mm 1854.150 Encoder check, ext=600mm 1854.500 Encoder=787.36mm ext=600mm 1858.750 Encoder=790.11mm ext=604mm 1859.400 Encoder=792.86mm ext=604mm 1861.550 Encoder=795.62mm ext=605mm 1865.500 Encoder=798.37mm ext=609mm 1868.450 Encoder=801.12mm ext=611mm 1872.500 Encoder=803.88mm ext=615mm 1874.900 Encoder=806.63mm ext=617mm 1878.900 Encoder=809.38mm ext=620mm 1879.550 Encoder=812.14mm ext=621mm 1881.400 Encoder=814.89mm ext=622mm 1885.050 Encoder=817.64mm ext=625mm 1886.850 Encoder=820.39mm ext=627mm 1887.500 Encoder=823.15mm ext=627mm 1890.600 Encoder check, ext=630mm 1891.300 Encoder=825.90mm ext=630mm 1893.400 Encoder=828.65mm ext=632mm 1893.800 Encoder=831.41mm ext=633mm 1893.950 Encoder=834.16mm ext=633mm 1897.700 Encoder=836.91mm ext=636mm 1897.950 Encoder=839.66mm ext=636mm 1898.350 Encoder=842.42mm ext=636mm 1900.000 Encoder=845.17mm ext=638mm 1900.050 Encoder=847.92mm ext=638mm 1900.650 Encoder=850.68mm ext=638mm 1904.600 Encoder=853.43mm ext=642mm 1906.800 Encoder=856.18mm ext=644mm 1907.250 Encoder=858.94mm ext=644mm 1907.650 Encoder=861.69mm ext=644mm 1911.500 Encoder=864.44mm ext=647mm 1913.700 Encoder=867.20mm ext=649mm 1914.150 Encoder=869.95mm ext=649mm 1917.900 Encoder=872.70mm ext=653mm 1918.600 Encoder=875.45mm ext=653mm 1919.950 Encoder=878.21mm ext=654mm 1920.800 Encoder=880.96mm ext=655mm 1923.850 Encoder=883.71mm ext=658mm 1924.150 Encoder=886.47mm ext=658mm 1924.300 Encoder=889.22mm ext=658mm 1925.900 Encoder=891.97mm ext=659mm 1925.950 Encoder check, ext=660mm 1929.450 Encoder=894.73mm ext=663mm 1929.600 Encoder=897.48mm ext=663mm 1930.050 Encoder=900.23mm ext=663mm 1932.550 Encoder=902.98mm ext=665mm 1936.300 Encoder=905.74mm ext=668mm 1939.100 Encoder=908.49mm ext=670mm 1943.400 Encoder=911.24mm ext=674mm 1945.900 Encoder=914.00mm ext=676mm 1949.600 Encoder=916.75mm ext=679mm 1949.750 Encoder=919.50mm ext=680mm 1950.200 Encoder=922.26mm ext=680mm 1952.800 Encoder=925.01mm ext=682mm 1956.550 Encoder=927.76mm ext=685mm 1958.500 Encoder=930.51mm ext=687mm 1958.550 Encoder=933.27mm ext=687mm 1959.050 Encoder=936.02mm ext=687mm 1962.350 Encoder check, ext=690mm 1962.850 Encoder=938.77mm ext=690mm 1965.050 Encoder=941.53mm ext=692mm 1968.600 Encoder=944.28mm ext=695mm 1968.700 Encoder=947.03mm ext=695mm 1969.150 Encoder=949.79mm ext=695mm 1971.600 Encoder=952.54mm ext=697mm 1975.450 Encoder=955.29mm ext=701mm 1977.500 Encoder=958.04mm ext=703mm 1978.350 Encoder=960.80mm ext=703mm 1982.500 Encoder=963.55mm ext=706mm 1985.050 Encoder=966.30mm ext=709mm 1988.750 Encoder=969.06mm ext=712mm 1988.900 Encoder=971.81mm ext=712mm 1989.350 Encoder=974.56mm ext=712mm 1991.950 Encoder=977.32mm ext=714mm 1995.650 Encoder=980.07mm ext=717mm 1997.400 Encoder=982.82mm ext=719mm 1997.750 Encoder check, ext=720mm 2002.050 Encoder=985.57mm ext=722mm 2003.950 Encoder=988.33mm ext=724mm 2007.400 Encoder=991.08mm ext=727mm 2010.000 Encoder=993.83mm ext=730mm 2014.400 Encoder=996.59mm ext=733mm 2016.700 Encoder=999.34mm ext=735mm 2021.100 Encoder=1002.09mm ext=739mm 2021.300 Encoder=1004.85mm ext=739mm 2021.850 Encoder=1007.60mm ext=739mm 2023.950 Encoder=1010.35mm ext=741mm 2027.550 Encoder=1013.10mm ext=744mm 2030.300 Encoder=1015.86mm ext=747mm 2030.950 Encoder=1018.61mm ext=747mm 2034.100 Encoder check, ext=750mm 2034.550 Encoder=1021.36mm ext=750mm 2036.550 Encoder=1024.12mm ext=752mm 2040.450 Encoder=1026.87mm ext=755mm 2041.050 Encoder=1029.62mm ext=755mm 2043.100 Encoder=1032.38mm ext=757mm 2046.550 Encoder=1035.13mm ext=760mm 2049.150 Encoder=1037.88mm ext=762mm 2049.900 Encoder=1040.63mm ext=762mm 2053.600 Encoder=1043.39mm ext=766mm 2055.900 Encoder=1046.14mm ext=768mm 2060.250 Encoder=1048.89mm ext=771mm 2063.150 Encoder=1051.65mm ext=773mm 2066.750 Encoder=1054.40mm ext=777mm 2069.450 Encoder=1057.15mm ext=779mm 2069.750 Encoder=1059.91mm ext=779mm 2070.150 Encoder=1062.66mm ext=779mm 2070.350 Encoder check, ext=780mm 2073.850 Encoder=1065.41mm ext=782mm 2075.600 Encoder=1068.16mm ext=784mm 2075.700 Encoder=1070.92mm ext=784mm 2075.900 Encoder=1073.67mm ext=784mm 2079.650 Encoder=1076.42mm ext=787mm 2080.300 Encoder=1079.18mm ext=788mm 2081.800 Encoder=1081.93mm ext=789mm 2082.000 Encoder=1084.68mm ext=789mm 2082.550 Encoder=1087.44mm ext=789mm 2085.550 Encoder=1090.19mm ext=792mm 2085.850 Encoder=1092.94mm ext=793mm 2086.000 Encoder=1095.69mm ext=793mm 2087.900 Encoder=1098.45mm ext=794mm 2092.950 Encoder=1101.20mm ext=798mm 2094.900 Encoder=1103.95mm ext=800mm 2098.800 Encoder=1106.71mm ext=804mm 2099.650 Encoder=1109.46mm ext=804mm 2101.800 Encoder=1112.21mm ext=806mm 2102.150 Encoder=1114.96mm ext=806mm 2102.650 Encoder=1117.72mm ext=806mm 2105.650 Encoder=1120.47mm ext=809mm 2105.950 Encoder=1123.22mm ext=809mm 2106.100 Encoder=1125.98mm ext=809mm 2106.250 Encoder check, ext=810mm 2108.100 Encoder=1128.73mm ext=811mm 2112.950 Encoder=1131.48mm ext=815mm 2114.650 Encoder=1134.24mm ext=817mm 2118.350 Encoder=1136.99mm ext=820mm 2120.850 Encoder=1139.74mm ext=822mm 2124.600 Encoder=1142.50mm ext=825mm 2126.900 Encoder=1145.25mm ext=827mm 2131.200 Encoder=1148.00mm ext=831mm 2133.850 Encoder=1150.75mm ext=832mm 2137.850 Encoder=1153.51mm ext=836mm 2140.850 Encoder=1156.26mm ext=838mm 2142.100 Encoder check, ext=840mm 2144.750 Encoder=1159.01mm ext=842mm 2147.150 Encoder=1161.77mm ext=844mm 2151.350 Encoder=1164.52mm ext=847mm 2153.700 Encoder=1167.27mm ext=849mm 2157.300 Encoder=1170.03mm ext=852mm 2159.150 Encoder=1172.78mm ext=854mm 2160.100 Encoder=1175.53mm ext=855mm 2163.550 Encoder=1178.28mm ext=857mm 2165.700 Encoder=1181.04mm ext=859mm 2169.550 Encoder=1183.79mm ext=863mm 2169.700 Encoder=1186.54mm ext=863mm 2170.150 Encoder=1189.30mm ext=863mm 2172.400 Encoder=1192.05mm ext=865mm 2173.200 Encoder=1194.80mm ext=865mm 2176.900 Encoder=1197.56mm ext=869mm 2177.850 Encoder check, ext=870mm 2179.100 Encoder=1200.31mm ext=871mm 2183.800 Encoder=1203.06mm ext=874mm 2186.050 Encoder=1205.81mm ext=876mm 2186.700 Encoder=1208.57mm ext=877mm 2189.750 Encoder=1211.32mm ext=880mm 2189.850 Encoder=1214.07mm ext=880mm 2190.350 Encoder=1216.83mm ext=880mm 2191.850 Encoder=1219.58mm ext=881mm 2192.000 Encoder=1222.33mm ext=881mm 2192.450 Encoder=1225.08mm ext=882mm 2196.200 Encoder=1227.84mm ext=885mm 2196.800 Encoder=1230.59mm ext=885mm 2198.300 Encoder=1233.34mm ext=887mm 2201.900 Encoder=1236.10mm ext=890mm 2202.100 Encoder=1238.85mm ext=890mm 2202.550 Encoder=1241.60mm ext=890mm 2204.950 Encoder=1244.36mm ext=892mm 2208.850 Encoder=1247.11mm ext=895mm 2211.550 Encoder=1249.86mm ext=897mm 2214.350 Encoder check, ext=900mm 2215.850 Encoder=1252.61mm ext=901mm 2218.350 Encoder=1255.37mm ext=903mm 2222.150 Encoder=1258.12mm ext=907mm 2222.250 Encoder=1260.87mm ext=907mm 2222.700 Encoder=1263.63mm ext=907mm 2225.250 Encoder=1266.38mm ext=909mm 2229.050 Encoder=1269.13mm ext=912mm 2231.500 Encoder=1271.89mm ext=914mm 2235.400 Encoder=1274.64mm ext=917mm 2237.450 Encoder=1277.39mm ext=919mm 2241.000 Encoder=1280.15mm ext=922mm 2241.100 Encoder=1282.90mm ext=922mm 2241.550 Encoder=1285.65mm ext=922mm 2244.100 Encoder=1288.40mm ext=924mm 2247.850 Encoder=1291.16mm ext=928mm 2249.700 Encoder check, ext=930mm 2250.000 Encoder=1293.91mm ext=930mm 2250.750 Encoder=1296.66mm ext=930mm 2255.000 Encoder=1299.42mm ext=933mm 2257.450 Encoder=1302.17mm ext=936mm 2261.400 Encoder=1304.92mm ext=939mm 2262.700 Encoder=1307.68mm ext=941mm 2264.850 Encoder=1310.43mm ext=945mm 2265.850 Encoder=1313.18mm ext=946mm 2267.850 Encoder=1315.93mm ext=950mm 2269.050 Encoder=1318.69mm ext=952mm 2270.900 Encoder=1321.44mm ext=955mm 2272.200 Encoder=1324.19mm ext=957mm 2274.000 Encoder check, ext=960mm 2274.400 Encoder=1326.95mm ext=960mm 2275.650 Encoder=1329.70mm ext=962mm 2277.850 Encoder=1332.45mm ext=966mm 2279.250 Encoder=1335.20mm ext=968mm 2281.250 Encoder=1337.96mm ext=971mm 2282.600 Encoder=1340.71mm ext=974mm 2284.700 Encoder=1343.46mm ext=977mm 2285.800 Encoder=1346.22mm ext=979mm 2287.800 Encoder=1348.97mm ext=982mm 2287.900 Encoder=1351.72mm ext=982mm 2288.100 Encoder=1354.48mm ext=982mm 2289.900 Encoder=1357.23mm ext=984mm 2293.400 Encoder=1359.98mm ext=987mm 2295.700 Encoder=1362.73mm ext=989mm 2296.000 Encoder check, ext=990mm 2297.900 Encoder=1365.49mm ext=993mm 2299.150 Encoder=1368.24mm ext=995mm 2301.300 Encoder=1370.99mm ext=998mm 2302.700 Encoder=1373.75mm ext=1000mm 2304.750 Encoder=1376.50mm ext=1004mm 2306.100 Encoder=1379.25mm ext=1006mm 2308.250 Encoder=1382.01mm ext=1009mm 2309.250 Encoder=1384.76mm ext=1011mm 2311.300 Encoder=1387.51mm ext=1014mm 2312.400 Encoder=1390.27mm ext=1016mm 2314.350 Encoder=1393.02mm ext=1019mm 2314.450 Encoder check, ext=1020mm 2315.650 Encoder=1395.77mm ext=1022mm 2317.850 Encoder=1398.52mm ext=1025mm 2319.100 Encoder=1401.28mm ext=1027mm 2321.300 Encoder=1404.03mm ext=1031mm 2323.600 Encoder=1406.78mm ext=1033mm 2327.250 Encoder=1409.54mm ext=1036mm 2330.050 Encoder=1412.29mm ext=1038mm 2332.200 Encoder=1415.04mm ext=1042mm 2333.200 Encoder=1417.80mm ext=1044mm 2335.250 Encoder=1420.55mm ext=1047mm 2336.350 Encoder=1423.30mm ext=1049mm 2336.900 Encoder check, ext=1050mm 2338.300 Encoder=1426.05mm ext=1052mm 2339.550 Encoder=1428.81mm ext=1054mm 2341.800 Encoder=1431.56mm ext=1058mm 2343.000 Encoder=1434.31mm ext=1060mm 2345.200 Encoder=1437.07mm ext=1063mm 2346.550 Encoder=1439.82mm ext=1065mm 2348.700 Encoder=1442.57mm ext=1069mm 2350.000 Encoder=1445.32mm ext=1071mm 2352.150 Encoder=1448.08mm ext=1074mm 2353.150 Encoder=1450.83mm ext=1076mm 2355.250 Encoder=1453.58mm ext=1079mm 2355.300 Encoder check, ext=1080mm 2356.350 Encoder=1456.34mm ext=1081mm 2356.850 Encoder=1459.09mm ext=1082mm 2359.550 Encoder=1461.84mm ext=1084mm 2360.250 Encoder=1464.60mm ext=1085mm 2361.900 Encoder=1467.35mm ext=1086mm 2365.250 Encoder=1470.10mm ext=1090mm 2366.500 Encoder=1472.85mm ext=1092mm 2368.800 Encoder=1475.61mm ext=1096mm 2370.100 Encoder=1478.36mm ext=1098mm 2372.200 Encoder=1481.11mm ext=1101mm 2373.500 Encoder=1483.87mm ext=1103mm 2375.650 Encoder=1486.62mm ext=1107mm 2376.700 Encoder=1489.37mm ext=1109mm 2377.250 Encoder check, ext=1110mm 2378.750 Encoder=1492.13mm ext=1112mm 2379.850 Encoder=1494.88mm ext=1114mm 2381.750 Encoder=1497.63mm ext=1117mm 2383.000 Encoder=1500.39mm ext=1119mm 2385.200 Encoder=1503.14mm ext=1123mm 2386.450 Encoder=1505.89mm ext=1125mm 2388.750 Encoder=1508.64mm ext=1128mm 2390.050 Encoder=1511.40mm ext=1130mm 2393.350 Encoder=1514.15mm ext=1134mm 2395.800 Encoder=1516.90mm ext=1136mm 2399.150 Encoder=1519.66mm ext=1139mm 2399.250 Encoder check, ext=1140mm 2400.200 Encoder=1522.41mm ext=1141mm 2402.250 Encoder=1525.16mm ext=1144mm 2403.350 Encoder=1527.92mm ext=1146mm 2405.300 Encoder=1530.67mm ext=1149mm 2406.550 Encoder=1533.42mm ext=1151mm 2408.850 Encoder=1536.17mm ext=1155mm 2410.000 Encoder=1538.93mm ext=1157mm 2412.250 Encoder=1541.68mm ext=1161mm 2413.600 Encoder=1544.43mm ext=1163mm 2415.650 Encoder=1547.19mm ext=1166mm 2417.050 Encoder=1549.94mm ext=1169mm 2417.650 Encoder check, ext=1170mm 2419.150 Encoder=1552.69mm ext=1172mm 2420.200 Encoder=1555.45mm ext=1174mm 2422.200 Encoder=1558.20mm ext=1177mm 2423.350 Encoder=1560.95mm ext=1179mm 2425.300 Encoder=1563.70mm ext=1182mm 2427.750 Encoder=1566.46mm ext=1184mm 2431.600 Encoder=1569.21mm ext=1188mm 2431.850 D_GCODE_END_OF_FILE 2586.850 $$$ CMD 2587.050 sleep
After print an information about firmware update is shown. This might mean that the newest firmware version is stored in the gcode file for the printer to display.
5 Firmware update
When the update firmware option is selected the USB port becomes active and reports as a Microchip USB HID Bootloader:
[75486.506468] usb 5-1: new full-speed USB device number 4 using xhci_hcd [75486.804247] usb 5-1: New USB device found, idVendor=04d8, idProduct=003c, bcdDevice= 0.02 [75486.804255] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [75486.804259] usb 5-1: Product: USB HID Bootloader [75486.804263] usb 5-1: Manufacturer: Microchip Technology Inc. [75486.812177] hid-generic 0003:04D8:003C.0005: hiddev96,hidraw4: USB HID v1.11 Device [Microchip Technology Inc. USB HID Bootloader] on usb-0000:10:00.0-1/input0
When you run the firmware update mode there is a SETTINGS.BIN file stored on the SD card which is I guess for persisting of settings during interface upgrade. The contents of this file are the following:
✗ hexdump -C < SETTINGS.BIN 00000000 01 00 00 00 5f 5e 56 c0 18 00 00 00 |...._^V.....| 0000000c ✗
When the Cube3D boots and detects the existence of this file it loads it and shows a "Settings restored" message on the LCD screen together with the following messages on the serial console:
0.000 Cube V2.07 0.000 Baud:227272 2.000 $$$ CMD 2.150 set u m 0x31 AOK 2.175 set w l 5 AOK 2.175 save Storing in config 2.175 get mac 2.200 D_LOAD_SETTINGS_FILE_CHECK_FS 2.200 D_LOAD_SETTINGS_FILE_CHECK_FILE 2.200 D_LOAD_SETTINGS_FILE_AND_RENAME 2.200 D_WRITE_NVM Mac Addr=00:06:66:21:f1:46 2.200 ver wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131 2.225 exit EXIT
The serial number of the printer is actually the MAC address of it's wireless card. For me this was 00066621f146.
The bootloader on the device was standard Microchip bootloader. It was properly detected and upgrade after connecting a PICKit3 to the board and running mplabx (mplabipe):
***************************************************** Connecting to MPLAB PICkit 3... Currently loaded firmware on PICkit 3 Firmware Suite Version.....01.28.90 * Firmware type..............PIC32MX Now Downloading new Firmware for target device: PIC32MX440F256H Downloading bootloader Bootloader download complete Programming download... Downloading RS... RS download complete Programming download... Downloading AP... AP download complete Programming download... Currently loaded firmware on PICkit 3 Firmware Suite Version.....01.54.00 Firmware type..............PIC32MX Target voltage detected Target device PIC32MX440F256H found. Device ID Revision = B4 B6 Reading current firmware: Reading... The following memory area(s) will be read: program memory: start address = 0x1d000000, end address = 0x1d03ffff boot config memory configuration memory Read complete Target device PIC32MX440F256H found. Device ID Revision = B4 B6
It seems like it updated the bootloader version. Don't know if this will be a problem
Reading memory…
6 Links
Forum thread about teardown of cubify cube 3: https://openbuilds.com/threads/tear-down-of-cubify-cube-3-3d-printer-convert-to-reprap.5689/page-3
Firmware files are supposed to be found at: http://cubify.s3.amazonaws.com/
