HIKVISION DS-7316HI-S
Table of Contents
1 Symptoms
The HIKVISION DS-7316HI-S is an NVR supporting analog CCTV cameras which I got for free. It was declared to be broken and indeed was failing to boot. The console output was providing the following hints:
U-Boot 1.2.0 (Nov 28 2009 - 10:58:12) DRAM: 256 MB AMD Flash devid:0x227e id3:0x2221 id4:0x2201 ARM Clock : 364MHz DDR Clock : 310MHz Hit ctrl+u to stop autoboot: 0 ### JFFS2 loading 'uImage' to 0x80700000 jffs2: scanning filesystem . done. jffs2: cannot find inode(uImage) ### JFFS2 load uImage error(0) ## Booting image at 80700000 ... Bad Magic Number HKVS #
1.1 RS-232 interface fix
The bootloader is U-Boot but the console did not work. It would print the above messages but did not accept any input. After investigating this I found out that the RS-232 interface receive path seemed to be broken so I replaced the SP2020EEN chip that was responsible. After this the boot process could be stopped and the U-Boot console accessed. Some discovery follows:
U-Boot 1.2.0 (Nov 28 2009 - 10:58:12) DRAM: 256 MB AMD Flash devid:0x227e id3:0x2221 id4:0x2201 ARM Clock : 364MHz DDR Clock : 310MHz Hit ctrl+u to stop autoboot: 0 HKVS # help ? - alias for 'help' bootd - boot default, i.e., run 'bootcmd' bootm - boot application image from memory cmp - memory compare cp - memory copy crc32 - checksum calculation format - format nand except bootloader area fsinfo - print information about filesystems fsload - load binary file from a filesystem image go - start application at address 'addr' help - print online help ls - list files in a directory (default /) md - memory display mm - memory modify (auto-incrementing) mtest - simple RAM test mw - memory write (fill) nand - NAND sub-system nboot - boot from NAND device ping - send ICMP ECHO_REQUEST to network host pready - set panel to ready printenv- print environment variables reset - Perform RESET of the CPU saveenv - save environment variables to persistent storage setenv - set environment variables tftpboot- boot image via network using TFTP protocol update - update digicap.dav updateb - update uboot(u-boot.bin) to nor updatebl- update ubl(ubl_646x.bin) to nand updatefs- update filesystem(davinci.img) to nand updatek - update kernel(uImage) to nand updates - serial update kernel or filesys HKVS # printenv bootargs=console=ttyS0,115200n8 initrd=2g,1 root=/dev/ram bootdelay=3 baudrate=115200 ipaddr=192.0.0.64 serverip=192.0.0.128 bootfile="uImage" netmask=255.255.255.0 bootcmd=fsload 0x80700000 uImage;bootm ethaddr=00:40:48:38:15:07 Environment size: 230/131068 bytes HKVS # fsinfo ### filesystem type is JFFS2 jffs2: scanning filesystem . done. Compression: NONE frag count: 1569 compressed sum: 6204344 uncompressed sum: 6204344 Compression: ZERO frag count: 0 compressed sum: 0 uncompressed sum: 0 Compression: RTIME frag count: 0 compressed sum: 0 uncompressed sum: 0 Compression: RUBINMIPS frag count: 0 compressed sum: 0 uncompressed sum: 0 Compression: COPY frag count: 0 compressed sum: 0 uncompressed sum: 0 Compression: DYNRUBIN frag count: 0 compressed sum: 0 uncompressed sum: 0 Compression: ZLIB frag count: 352 compressed sum: 591484 uncompressed sum: 1422185 HKVS # ls -rwxrwxrwx 711436 Thu Jan 01 00:00:00 1970 rootfs.img -rwxrwxrwx 829440 Thu Jan 01 00:00:00 1970 720.422 -rwxrwxrwx 269846 Thu Jan 01 00:00:00 1970 ds8062_fpga.rbf -rwxrwxrwx 267 Thu Jan 01 00:00:00 1970 initrun.sh -rwxrwxrwx 4297989 Thu Jan 01 00:00:00 1970 guirc.tar.gz -rwxrwxrwx 1510288 Thu Jan 01 00:00:00 1970 webs.tar.gz HKVS #
We can see what is wrong here, the 'bootcmd' contains instructions to load the uImage from jffs2 but there is no file named uImage there so the boot process fails.
1.2 Firmware restore
I found a firmware image and a user's manual on a Polish CCTV shop download site (old-skool plain file server!). In order to perform the update you need to setup...
