Features
- Customized for Raspberry Pi 4 Model B, make it become a real desktop PC for all.
- Re-locate all of the ports to the rear, and make GPIO pins easy to access with at-a-glance pin out legend next to the gpio.
- An ice tower cooler was built-in, that keeps the CPU down to 40℃/104℉ even when overclocked
- A nice and solid metal case, customized cuts for all ports, lamps and wifi signal, while enhancing the cooling effectiveness, lightweight enough to make the Raspberry Pi 4 become a real portable pocket PC.
Specification
- An air cooler that keeps the CPU down to 40℃/104℉ even at its full throttle, and yes, it has the kind of RGB every gamer hypes about.
- A GPIO adapter board that puts the GPIO to the back.
- An adapter board that rearranges all the ports to one side.
- A push-button switch convenient to do a safe shutdown.
- A 0.96 inch OLED display shows IP, CPU/memory load by default. You can also program it to display anything you want.
- A nice and solid metal case, customized cuts for all ports, lamps and wifi signal, while enhancing the cooling effectiveness.
Package Including
- 1 × Upper cover plate with OLED display
- 1 × Lower cover plate
- 1 × GPIO adapter board
- 1 × HDMI adapter board
- 1 × ICE towel cooler
- 1 × Power switch
- 2 × Wires for power switch and screen
- 1 × Power supply board for fan
- 4 × Rubber feet
- 1 × Elastomeric heat-conducting pad
- 1 × Screw pack
UCTRONICS
TM
Giuseppe
Salvatore
