The Radar module has been mounted on the DIY PCB with a 2 stage op amp for each signal output. Tested all ok. Great care needs to be taken to prevent damage to the module by static voltage. Next step is to hook up the oscilloscope and have a look at the output wave forms again.
GOAT INDUSTRIES
