The echo.pal example program reads characters from the serial port and echos them out as they are entered. When Enter is pressed, the entire line gets sent to the serial port.
In the previous log I created a utility bin2mif that does a simple translation of the DEC bin file into a memory initialization file. The program only copies code sections and doesn't deal with non-contiguous code sections. This limitation is fine for the data since it should all be set to zero anyway but it's a problem for the non-contiguous code sections in echo.pal.
Here's the echo.lst file:
1 / Serial port test (echo) 2 / http://homepage.divms.uiowa.edu/~jones/pdp8/man/tty.html 3 0010 *10 4 00010 0000 linep, 0 5 0020 *20 6 00020 0000 saved, 0 7 00021 0000 count, 0 8 0400 *400 / Line stored here 9 00400 0000 line, 0 10 0200 *200 11 00200 7200 CLA / Clear Accumulator 12 00201 6046 TLS / Teleprinter Load and start 13 00202 7200 newl, CLA / Clear Accumulator 14 00203 1377 TAD (line-1) 15 00204 3010 DCA linep 16 00205 6031 newc, KSF / Keyboard Skip if Flag (input data is ready) 17 00206 5205 JMP .-1 / 18 00207 6036 KRB / Keyboard Read and begin next read 19 00210 0376 AND (177) / Get rid of parity bit 20 00211 6041 TSF / Teleprinter Skip if Flag 21 00212 5211 JMP .-1 22 00213 6046 TLS / Teleprinter Load and start (Echo it) 23 00214 3020 DCA saved / save a copy 24 00215 1020 TAD saved 25 00216 3410 DCA I linep / store it away 26 00217 1020 TAD saved 27 00220 1375 TAD (-15) / CR character? 28 00221 7440 SZA / finished line if so - Skip next instruction if Zero Accumulator 29 00222 5205 JMP newc 30 00223 1374 TAD (12) / Echo line feed as well 31 00224 6041 TSF / Teleprinter Skip if Flag 32 00225 5224 JMP .-1 33 00226 6046 TLS / Teleprinter Load and start (Echo it) 34 / Now echo the line 35 00227 7200 CLA / Clear Accumulator 36 00230 1373 TAD (-line) 37 00231 1010 TAD linep / get number of characters 38 00232 7040 CMA / minus the number 39 00233 3021 DCA count 40 00234 1377 TAD (line-1) / reset starting address 41 00235 3010 DCA linep 42 00236 7200 echoc, CLA / Clear Accumulator 43 00237 1410 TAD I linep / get character 44 00240 6041 TSF / Teleprinter Skip if Flag 45 00241 5240 JMP .-1 46 00242 6046 TLS / Teleprinter Load and start 47 00243 2021 ISZ count / Increment and store 48 00244 5236 JMP echoc 49 00245 7200 CLA / Clear Accumulator 50 00246 1374 TAD (12) 51 00247 6041 TSF / Teleprinter Skip if Flag 52 00250 5247 JMP .-1 53 00251 6046 TLS / Teleprinter Load and start 54 00252 5202 JMP newl 00373 7400 00374 0012 00375 7763
The problem here is the values in locations 373-375 (oct). They get placed immediately after the code at 263-255, These can be manually inserted using the In System Memory editor.
The Quartus In System Memory Editor can be used to do an export of the data (first select all). Saved the code as echo_fixed.mif.
The result is that the echo code runs on the PDP-8 FPGA.
