The echo.pal example program reads characters from the serial port and echos them out as they are entered. When Enter is pressed, the entire line gets sent to the serial port.
In the previous log I created a utility bin2mif that does a simple translation of the DEC bin file into a memory initialization file. The program only copies code sections and doesn't deal with non-contiguous code sections. This limitation is fine for the data since it should all be set to zero anyway but it's a problem for the non-contiguous code sections in echo.pal.
Here's the echo.lst file:
1 / Serial port test (echo)
2 / http://homepage.divms.uiowa.edu/~jones/pdp8/man/tty.html
3 0010 *10
4 00010 0000 linep, 0
5 0020 *20
6 00020 0000 saved, 0
7 00021 0000 count, 0
8 0400 *400 / Line stored here
9 00400 0000 line, 0
10 0200 *200
11 00200 7200 CLA / Clear Accumulator
12 00201 6046 TLS / Teleprinter Load and start
13 00202 7200 newl, CLA / Clear Accumulator
14 00203 1377 TAD (line-1)
15 00204 3010 DCA linep
16 00205 6031 newc, KSF / Keyboard Skip if Flag (input data is ready)
17 00206 5205 JMP .-1 /
18 00207 6036 KRB / Keyboard Read and begin next read
19 00210 0376 AND (177) / Get rid of parity bit
20 00211 6041 TSF / Teleprinter Skip if Flag
21 00212 5211 JMP .-1
22 00213 6046 TLS / Teleprinter Load and start (Echo it)
23 00214 3020 DCA saved / save a copy
24 00215 1020 TAD saved
25 00216 3410 DCA I linep / store it away
26 00217 1020 TAD saved
27 00220 1375 TAD (-15) / CR character?
28 00221 7440 SZA / finished line if so - Skip next instruction if Zero Accumulator
29 00222 5205 JMP newc
30 00223 1374 TAD (12) / Echo line feed as well
31 00224 6041 TSF / Teleprinter Skip if Flag
32 00225 5224 JMP .-1
33 00226 6046 TLS / Teleprinter Load and start (Echo it)
34 / Now echo the line
35 00227 7200 CLA / Clear Accumulator
36 00230 1373 TAD (-line)
37 00231 1010 TAD linep / get number of characters
38 00232 7040 CMA / minus the number
39 00233 3021 DCA count
40 00234 1377 TAD (line-1) / reset starting address
41 00235 3010 DCA linep
42 00236 7200 echoc, CLA / Clear Accumulator
43 00237 1410 TAD I linep / get character
44 00240 6041 TSF / Teleprinter Skip if Flag
45 00241 5240 JMP .-1
46 00242 6046 TLS / Teleprinter Load and start
47 00243 2021 ISZ count / Increment and store
48 00244 5236 JMP echoc
49 00245 7200 CLA / Clear Accumulator
50 00246 1374 TAD (12)
51 00247 6041 TSF / Teleprinter Skip if Flag
52 00250 5247 JMP .-1
53 00251 6046 TLS / Teleprinter Load and start
54 00252 5202 JMP newl
00373 7400
00374 0012
00375 7763
The problem here is the values in locations 373-375 (oct). They get placed immediately after the code at 263-255, These can be manually inserted using the In System Memory editor.
The Quartus In System Memory Editor can be used to do an export of the data (first select all). Saved the code as echo_fixed.mif.
The result is that the echo code runs on the PDP-8 FPGA.
land-boards.com
