Since the last post I have cleaned up some of the code and added a couple of missing features that slipped through before. The construction steps have been documented along with a few areas of the code that wern't documented. This means the project is now complete.
The project build guide and data required to build and program the device have been added to the files section as well as to the releases of the respective github repositories.
