runout and clog test of laser filament sensor
,with the micro USB you can get the raw data of the sensor and motor, update the mcu firmware, set sensitive value.
if it detect the clog or runout,it will set the output signal line to zero voltage which tell the mother board to pause printing.
so it works with all other motherboard which have run out connector
mark
Alexey Volkov
Deezmaker
On the graph I don't see any difference between normal and clogged plots.
What should we see?
