A measuring wheel made out of a tape dispenser, which you can use with a ball winder to measure how much yarn is in a leftover ball.
You’ll need:
Take the roll of tape and trace the inside and outside of the roll. Make two donuts. Cut them out with scissors or an exacto knife.
Take your yarn guides and push them onto either end of the core of your tape dispenser. They may stay put as-is, but ours loosened and flopped after winding a few balls, so we recommend hot-gluing them in place. Also hot-glue the magnet to the outside of one of the yarn guides.
Note: we have an older-style tape dispenser with a round core. If yours has a triangular core, that’s OK too, proceed!
