RC Race Truck in 1:87 scale with FPV-System
radio controlled race truck with 3D printed chassis with FPV-System
1.1k views
0 followers
I have designed a chassis for a 1:87 scale racing truck. This chassis is specially designed for Rietze racing trucks, but can be used with a little adaptation also for other trucks.
The 180mAh Lipo sits in the bottom of the frame. The servo and the receiver are in the cab.
The drive is done by a spur gear, so the handling is very pleasant.
The chassis is designed in such a way that the components only need to be glued in place if the 3D printing is decent.
Have a look at the link to my website in the link section.
Information about the FPV system will follow.
Information about the transponder for lap counting will also follow.
Rahmen_OPGC_V3_Rietze.stl
Frame for Racetrucks in 1.87 scale from Rietze
Standard Tesselated Geometry - 182.99 kB - 05/04/2021 at 08:28
Download
  • 1
    All used components, Deltang RX45 receiver, 3D printed chassis, steering axle, micro servo, motor, Lipo, gears and bearings.
View all instructions
Rich text editor
