Really cool update that I'm super happy about. Sometimes the slide would be just outside the camera view. I added code for the camera image to adjust the slide position so it is center of the camera view. It is really neat to see it work, the image slowly moves the slide up or down to get into the center.
When the image switches to threshold mode, (white and black) you can see the slide adjust to center.
