Case designed
A project log for CNC Mod Board & Pendant
A board and pendant primarily designed for adding functionality to existing machines that can also function as main board in some cases
zackZack 05/10/2021 at 13:450 Comments
Designed a case for the board.  Allows for easy access from top for all the connectors (except USB).
