Hackaday.io Hackaday.io
Sign up Log in
Digital Bird WIFI Remote
This is a short project covering the WIFI remote which drives all parts of the Digital Bird motion control system.
digitalbird01digitalbird01
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
527 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
442
0
527
4
Team (1)
  • digitalbird01digitalbird01
Join this project's team
  • DigitalBird-Motion-Control
  • Digital Bird Kits
  • Camera Slider parts
  • Pan Tilt Head Parts
  • WIFI Remote Parts
  • See it all in action
hardware
ongoing project
wifi remote pan tilt Camera Slider Video Turntable nextion ESP32 3d printable
This project was created on 05/08/2021 and last updated 5 years ago.
Description
Update and Warning:
It has come to my attention that various batteries do not all come with the positive and negative on the same side of the plug please ensure that the positive and negative on your battery pack is correct for the project. The positive red wire should pass through to the red wire on the harness linked to the switch. Note also that the 1200mah battery has been replaced with a 2000mah High Discharge rated unit.
This is the Digital Bird WIFI remote split away from the slider because it may also be used for other parts of the Digital Bird Camera motion control system independently and I decided it warranted its own project heading.
Component Kits : https://digital-bird-motion-control.myshopify.com
See it in action : https://youtu.be/0aQ5hq3H00k
Camera Slider : https://www.thingiverse.com/thing:4689312
Pan Tilt Head: https://www.thingiverse.com/thing:4842363
Software : https://github.com/digitalbird01/DigitalBird-Camera-Slider
Details
Log In/Sign up to comment
Sign up with Github
OR
Web controlled macro rail for focus stacking
Project Owner Contributor
ESP32 Macro Rail
raduprvraduprv
Hackaday Prize 2020
RT-Thread Community DIY Project
DIY A MecaNum Wheel Car with Phone Remote Control.
rt-thread-iot-osRT-Thread IoT OS
By wiring simple electrical components like relay, neon bulb and a 9V battery, back emf from the relay can be used to light the bulb.
Glow a neon bulb using 9V DC battery and a relay!
meinsamayhunmeinsamayhun
Fully Automatic Open Source Quadcopter and Landing/Charging Platform, made from scratch.
Fiva Drone: Automatic Landing/Charging Quadcopter
camilo-rojasCamilo Rojas
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Digital Bird WIFI Remote", please tell us the reason.
Send message
Remove Member
