Making a test box for the electronics, to find out how it will look. First, it is very bulky, too bulky for the right crankarm. Therefore the coin-cell battery has to be removed from the top of the PCB, to the side. Since the battery holder does not come pre-soldered on the PCB, the current PCB file are ok (just solder some wire on) but I will probably change that since I haven't ordered it yet. If someone knows about a small battery that fits this project better, please contact me.
