It Works!
A project log for Computie 68k
A series of simple 68010 and 68030-based computers with a Unix-like OS
transistorfettransistor_fet • 12/18/2021 at 05:44•0 Comments
The board will run the monitor software and boot the OS.  I still have a problem with the CompactFlash card, but everything else seems to be working.  I'm so happy, especially after making a mistake and using the wrong footprint for the two 16SSOP logic chips.  I had to bend the pins under the package and try to solder them upside down, without hot air, just a fine tipped soldering iron.
