Hackaday.io Hackaday.io
Sign up Log in
ATtiny13A TinyNeoController
Control almost any number of NeoPixels with an ATtiny13A and an IR Remote
stefan-wagnerStefan Wagner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
202 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
497
0
202
9
Team (1)
  • stefan-wagnerStefan Wagner
Join this project's team
  • Project Files (Github)
  • Project Files (EasyEDA)
Software
completed project
avr attiny attiny13 ATtiny13a IR REMOTE arduino project diy pcb Neopixel led
This project was created on 05/13/2021 and last updated 2 years ago.
Description
An ATtiny13 is more than sufficient to control almost any number of NeoPixels via an IR remote. The NeoController was originally developed as a tester for 800kHz NeoPixel strips. Since there was still so much flash left in the ATtiny13, an IR receiver was integrated so that some parameters can be controlled with an IR remote control. In this way, it is also suitable as a simple and cheap remote-controlled control unit for NeoPixels. Due to its small size (21.6mm x 11.4mm), it can be soldered directly to the LED strip without any problems. The power supply via a USB-C connection enables currents of up to 3A. There is still more than a third of the flash memory left for additional ideas.
Details
Log In/Sign up to comment
Sign up with Github
OR
Integrate control of mini-split air conditioner to SmartThings with NodeMCU and IR LED and measure Temp and Humidity
Project Owner Contributor
Control Infrared Mini-split AC with SmartThings
erik-tellierErik Tellier
Remote Control Animatronic Plush Shark
OPShark
dan-sheadelDan Sheadel
It's now implemented PS2 remote control, aircraft model remote control, and PPM receiver manually controlled.
How to Make a Lunar Rover From Zero?
rt-thread-iot-osRT-Thread IoT OS
dropped TTL for a Ti430 to control a pop-less mic mute
mic mute v4
johnfosterjohnfoster
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ATtiny13A TinyNeoController", please tell us the reason.
Send message
Remove Member
