Everything you wanted to know about configuring the TI-86 link port...
In the form of an Assembly Include-file which can be used in Zac, on the calculator... If you're crazy, like me, and don't mind sacrificing 6KB for some at-hand documentation.
I'll attach the actual file in this project's Files-Section....
https://cdn.hackaday.io/files/1797727691365248/iPort7.86p
View this one if your browser isn't showing monospace:
https://cdn.hackaday.io/files/1797727691365248/iPort7.86p.txt
A:TI-86 Port 7 Info/Defines ;TI's Link-Port ;Note that TI-OS watches the ;link-port in _getkey(?) ;which is called in the ;200Hz interrupt(?). ;Best: ; 1 disable ints ; 2 dont connect custom ; harware until AFTER 1 ; 3 dont call OS-supplied ; keyboard funtions ; 4 disconnect custom hardware ; before 5 ; 5 restore Port 7 to TI-OS's ; idle state ; (call PORT7_restore) ; 6 reenable interrupts ;Port 7 : ;Internal: ;CPU I/O : 6V ;Buffers : | ; vv : $ 10K Resistor ;ID-<|-+------+ ;OD-|>-' : V Diode ;OED-' : +------->< wire ; : $ 470 Resistor ;OT-|>-+--~-|< NPN Transistor ;OET-' | : | ;IT-<|-' : GND ; Redrawn ;6V--~--+-|>|---+----->< wire ; 10K | pL,Z}| 470 ;..... |{H,L,Z '---~----. ;CPU :..|.......... b | c ; ID-<|-+ IT-<|-+--~--|< NPN ; OD-|>-' OT-|>-': | e ; OED-' OET-' : GND ;Through Diode: ; ID = Input Buffer ; OD = Output Buffer ; OED = Output Enable for ; Buffer to Diode ;Through Transistor: ; OT = Output to Transistor ; OET = Output Enable for ; Buffer to Transistor ; (almost always ON=1) ; IT = Input Buffer ("from ; Transistor" base) ; OET OED OT OD Wire ID ; v---unknown effect------- ; 0 0 X X pu? pu? ; 0 1 X 0 Z? 0 ; 0 1 X 1 H 1 ; ^---unknown effect------- ; best avoid "floating" base ;.--used by TI-OS for linking ;V ; OET OED OT OD Wire ID ;H 1 0 0 X pH pH ; 1 0 1 X vL vL ; 1 1 0 0 hZ 0 ; 1 1 0 1 dH 1* ;L 1 1 1 0 pL 0 ;* UNKNOWN if CPU output has ; the high drive-strength to ; overcome 470ohms to GND ; --------V--V------------- ; 1 1 1 1 H? 1* ; --------^--^------------- ; prb best to avoid competing ; drivers, though CPU driving ; high through 470 to GND may ; be OK, plausibly useful ;pL == pulled-Low through ; transistor/resistor. ; 6V/ID/OD/10K-pull-up ; effectively isolated ; from wire via reverse ; diode (see hZ note) ; 470 ; ~= GND --~-->< wire ; BUT: ID=0!!! ; ; pL is TI-OS's Link Low. ; Effectively output-only. ; Despite resistor, pulling ; the wire high externally ; will not be measured. ; For that, see vL. ;pH == pulled-High ; through diode: ; 6V --~---+-|>|-->< wire ; ID --<|--' ; 10K ; ~= 6V --~-->< ID=wire ; ; pH is TI-OS's Link Idle. ; Bidirectional. ; Wire/ID Reads High unless ; other device pulls low ; This MIGHT also work with ; similar bidir pulled-up ; open-collector interfaces ; such as i2c. ; However beware 6V! ; Ironically, this MIGHT work ; well with HIGHER-voltage ; OC/PU interfaces, since ; diode should prevent e.g. ; 12V from reaching CPU. ; Am presently working on ; such and cant quite ; convince myself to risk it ;dH == Driven High* from ; CPU Output via Diode ; OD=1 ---|>--+--|>|-->< wire ; ID=1 ---<|--' ; depending on connected ; circuit, may override ; circuit's pulling wire low ; E.g. another TI-86 could ; activate its low-pulling ; transistor (see vL), yet ; read the wire as high* ;hZ == High-Impedance via ; Reverse Output Diode: ; OD=0 --|>--+--|>|-->< wire ; ID=0 --<|--' ; note diode orientation ; effectively isolates ; wire and ID ; OD=0 --|>--+-- -->< wire ; ID=0 --<|--' ; May be useful e.g. with ; multiple devices on a bus ; OR to 3V3 logic input w/ ; external pull-up resistor ;vL == pulled-Low through ; Voltage-Divider: ; 10K 470 ; 6V --~---+-|>|-+--~-- GND ; ID --<|--' '-->< wire ; 470 ; ~= 0.3V --~-->< ID=wire ; ; vL Can Be Useful ; e.g. external 3V3 logic ; outputs to TI-86 ; :logic output : ; : __|__ __|__ : ; 3V3_:__7 \_._/ \,_:_GND ; :..PNP.|.NPN..: ; | ; 10K | 470 ; 6V --~--+-|>|-+--~---- GND ; ID --<|-' ; NOTE: Logic MUST Drive 8mA ; (Also CPU In=High Threshold ; Voltage unknown/untested) ; other I/O configs wont work ; pH: puts 6V INTO 3V3 output ; Can be bad when Logic=H ; dH: ditto worse, also ID=1 ; pL: ID=0 regardless of wire ; hZ: ditto ;port 7 (READ): ; TODO: VERIFY ;Bits 7-4 read-back config bit ; bit 7: =OET white wire ; bit 6: =OET red wire ; bit 5: =OED white ; bit 4: =OED red ;Bits 3,2 *usually* will, too ; bit 3: IT~=OT white ; bit 2: IT~=OT red ;Bits 1,0 read the "inputs" ;Though may differ per config ; bit 1: ID ~=white wire ; bit 0: ID ~=red wire ;port 7 (WRITE/Configure): ;.-bit 7: OET white wire ;|-bit 6: OET red wire ;|-bit 5: OED white ;|-bit 4: OED red ;|-bit 3: OT white ;|-bit 2: OT red ;|-bit 1: OD white ;|-bit 0: OD red ;| ;| "DIR"/OE OUT(VAL) ;| 7 6 5 4 3 2 1 0 port bit ;| 4 3 2 1 4 3 2 1 port pin ;'> T T D D T T D D ; w r w r w r w r wht/red ;TI-OS/linking uses: ;C0 1 1 0 0 0 0 X X pH pH ;D4 1 1 0 1 0 1 X 0 pH pL ;E8 1 1 1 0 1 0 0 X pL pH ;and rarely (on link error?): ;FC 1 1 1 1 1 1 0 0 pL pL PORT7_WpH_RpH =$C0 PORT7_WpH_RpL =$D4 PORT7_WpL_RpH =$E8 PORT7_WpL_RpL =$FC ;pL: input=0, wire pulled low ;pH: input=wire, pulled high ;vL: input=wire ~= pulled low ;dH: input=1, wire driven high ;hZ: input=0, wire high-Z PORT7_W_MASK =%10101010 PORT7_WpL =%10101000 PORT7_WpH =%10000000 PORT7_WvL =%10001000 PORT7_WdH =%10100010 PORT7_WhZ =%10100000 PORT7_R_MASK =%01010101 PORT7_RpL =%01010100 PORT7_RpH =%01000000 PORT7_RvL =%01000100 PORT7_RdH =%01010001 PORT7_RhZ =%01010000 ;NOTE: PORT READ does NOT ; match last PORT WRITE ; (in lowest four bits) ;THUS: can NOT simply ; read/modify/write ;ALSO: can NOT simply read ; port 7 at program entry ; then restore that value ; before returning to TI-OS. ;THUS CALL PORT7_restore, ; or USE PORT7_TIOS_IDLE, ; AND THEN reenable interrupts ; before exit PORT7_TIOS_IDLE =PORT7_WpH_RpH ;restore port 7 for TI-OS ; Dont forget to re-enable ; interrupts, thereafter PORT7_restore: ld a,PORT7_TIOS_IDLE out (7),a ret ;E.G. Custom for 3V3-serial: ; wht red ; Rx Tx ;C8 1 1 0 0 1 0 X X vL pH ;DC 1 1 0 1 1 1 X 0 vL pL PORT7_WvL_RpH =$C8 PORT7_WvL_RpL =$DC ;wh=input=vL prevents 6V from ; feeding into 3V3 output. ; Output must drive 8ma! ;red=output=pH ONLY SAFE HERE ; because My converter has ; a zener at Rx ; (OTW maybe use hZ ; AND add pull-up to 3V3) ;Then in iUART3V3: ; TxLOW =PORT7_WvL_RpL ; TxHIGH =PORT7_WvL_RpH
