Everything you wanted to know about configuring the TI-86 link port...
In the form of an Assembly Include-file which can be used in Zac, on the calculator... If you're crazy, like me, and don't mind sacrificing 6KB for some at-hand documentation.
I'll attach the actual file in this project's Files-Section....
https://cdn.hackaday.io/files/1797727691365248/iPort7.86p
View this one if your browser isn't showing monospace:
https://cdn.hackaday.io/files/1797727691365248/iPort7.86p.txt
A:TI-86 Port 7 Info/Defines
;TI's Link-Port
;Note that TI-OS watches the
;link-port in _getkey(?)
;which is called in the
;200Hz interrupt(?).
;Best:
; 1 disable ints
; 2 dont connect custom
; harware until AFTER 1
; 3 dont call OS-supplied
; keyboard funtions
; 4 disconnect custom hardware
; before 5
; 5 restore Port 7 to TI-OS's
; idle state
; (call PORT7_restore)
; 6 reenable interrupts
;Port 7 :
;Internal:
;CPU I/O : 6V
;Buffers : |
; vv : $ 10K Resistor
;ID-<|-+------+
;OD-|>-' : V Diode
;OED-' : +------->< wire
; : $ 470 Resistor
;OT-|>-+--~-|< NPN Transistor
;OET-' | : |
;IT-<|-' : GND
; Redrawn
;6V--~--+-|>|---+----->< wire
; 10K | pL,Z}| 470
;..... |{H,L,Z '---~----.
;CPU :..|.......... b | c
; ID-<|-+ IT-<|-+--~--|< NPN
; OD-|>-' OT-|>-': | e
; OED-' OET-' : GND
;Through Diode:
; ID = Input Buffer
; OD = Output Buffer
; OED = Output Enable for
; Buffer to Diode
;Through Transistor:
; OT = Output to Transistor
; OET = Output Enable for
; Buffer to Transistor
; (almost always ON=1)
; IT = Input Buffer ("from
; Transistor" base)
; OET OED OT OD Wire ID
; v---unknown effect-------
; 0 0 X X pu? pu?
; 0 1 X 0 Z? 0
; 0 1 X 1 H 1
; ^---unknown effect-------
; best avoid "floating" base
;.--used by TI-OS for linking
;V
;H 1 0 0 X pH pH
; 1 0 1 X vL vL
; 1 1 0 0 hZ 0
; 1 1 0 1 dH 1*
;L 1 1 1 0 pL 0
;* UNKNOWN if CPU output has
; the high drive-strength to
; overcome 470ohms to GND
; --------V--V-------------
; 1 1 1 1 H? 1*
; prb best to avoid competing
; drivers, though CPU driving
; high through 470 to GND may
; be OK, plausibly useful
;pL == pulled-Low through
; transistor/resistor.
; 6V/ID/OD/10K-pull-up
; effectively isolated
; from wire via reverse
; diode (see hZ note)
; 470
; ~= GND --~-->< wire
; BUT: ID=0!!!
; pL is TI-OS's Link Low.
; Effectively output-only.
; Despite resistor, pulling
; the wire high externally
; will not be measured.
; For that, see vL.
;pH == pulled-High
; through diode:
; 6V --~---+-|>|-->< wire
; ID --<|--'
; 10K
; ~= 6V --~-->< ID=wire
; pH is TI-OS's Link Idle.
; Bidirectional.
; Wire/ID Reads High unless
; other device pulls low
; This MIGHT also work with
; similar bidir pulled-up
; open-collector interfaces
; such as i2c.
; However beware 6V!
; Ironically, this MIGHT work
; well with HIGHER-voltage
; OC/PU interfaces, since
; diode should prevent e.g.
; 12V from reaching CPU.
; Am presently working on
; such and cant quite
; convince myself to risk it
;dH == Driven High* from
; CPU Output via Diode
; OD=1 ---|>--+--|>|-->< wire
; ID=1 ---<|--'
; depending on connected
; circuit, may override
; circuit's pulling wire low
; E.g. another TI-86 could
; activate its low-pulling
; transistor (see vL), yet
; read the wire as high*
;hZ == High-Impedance via
; Reverse Output Diode:
; OD=0 --|>--+--|>|-->< wire
; ID=0 --<|--'
; note diode orientation
; effectively isolates
; wire and ID
; OD=0 --|>--+-- -->< wire
; ID=0 --<|--'
; May be useful e.g. with
; multiple devices on a bus
; OR to 3V3 logic input w/
; external pull-up resistor
;vL == pulled-Low through
; Voltage-Divider:
; 10K 470
; 6V --~---+-|>|-+--~-- GND
; ID --<|--' '-->< wire
; 470
; ~= 0.3V --~-->< ID=wire
; vL Can Be Useful
; e.g. external 3V3 logic
; outputs to TI-86
; :logic output :
; : __|__ __|__ :
; 3V3_:__7 \_._/ \,_:_GND
; :..PNP.|.NPN..:
; 10K | 470
; 6V --~--+-|>|-+--~---- GND
; ID --<|-'
; NOTE: Logic MUST Drive 8mA
; (Also CPU In=High Threshold
; Voltage unknown/untested)
; other I/O configs wont work
; pH: puts 6V INTO 3V3 output
; Can be bad when Logic=H
; dH: ditto worse, also ID=1
; pL: ID=0 regardless of wire
; hZ: ditto
;port 7 (READ):
; TODO: VERIFY
;Bits 7-4 read-back config bit
; bit 7: =OET white wire
; bit 6: =OET red wire
; bit 5: =OED white
; bit 4: =OED red
;Bits 3,2 *usually* will, too
; bit 3: IT~=OT white
; bit 2: IT~=OT red
;Bits 1,0 read the "inputs"
;Though may differ per config
; bit 1: ID ~=white wire
; bit 0: ID ~=red wire
;port 7 (WRITE/Configure):
;.-bit 7: OET white wire
;|-bit 6: OET red wire
;|-bit 5: OED white
;|-bit 4: OED red
;|-bit 3: OT white
;|-bit 2: OT red
;|-bit 1: OD white
;|-bit 0: OD red
;| "DIR"/OE OUT(VAL)
;| 7 6 5 4 3 2 1 0 port bit
;| 4 3 2 1 4 3 2 1 port pin
;'> T T D D T T D D
; w r w r w r w r wht/red
;TI-OS/linking uses:
;C0 1 1 0 0 0 0 X X pH pH
;D4 1 1 0 1 0 1 X 0 pH pL
;E8 1 1 1 0 1 0 0 X pL pH
;and rarely (on link error?):
;FC 1 1 1 1 1 1 0 0 pL pL
PORT7_WpH_RpH =$C0
PORT7_WpH_RpL =$D4
PORT7_WpL_RpH =$E8
PORT7_WpL_RpL =$FC
;pL: input=0, wire pulled low
;pH: input=wire, pulled high
;vL: input=wire ~= pulled low
;dH: input=1, wire driven high
;hZ: input=0, wire high-Z
PORT7_W_MASK =%10101010
PORT7_WpL =%10101000
PORT7_WpH =%10000000
PORT7_WvL =%10001000
PORT7_WdH =%10100010
PORT7_WhZ =%10100000
PORT7_R_MASK =%01010101
PORT7_RpL =%01010100
PORT7_RpH =%01000000
PORT7_RvL =%01000100
PORT7_RdH =%01010001
PORT7_RhZ =%01010000
;NOTE: PORT READ does NOT
; match last PORT WRITE
; (in lowest four bits)
;THUS: can NOT simply
; read/modify/write
;ALSO: can NOT simply read
; port 7 at program entry
; then restore that value
; before returning to TI-OS.
;THUS CALL PORT7_restore,
; or USE PORT7_TIOS_IDLE,
; AND THEN reenable interrupts
; before exit
PORT7_TIOS_IDLE =PORT7_WpH_RpH
;restore port 7 for TI-OS
; Dont forget to re-enable
; interrupts, thereafter
PORT7_restore:
ld a,PORT7_TIOS_IDLE
out (7),a
ret
;E.G. Custom for 3V3-serial:
; wht red
; Rx Tx
;C8 1 1 0 0 1 0 X X vL pH
;DC 1 1 0 1 1 1 X 0 vL pL
PORT7_WvL_RpH =$C8
PORT7_WvL_RpL =$DC
;wh=input=vL prevents 6V from
; feeding into 3V3 output.
; Output must drive 8ma!
;red=output=pH ONLY SAFE HERE
; because My converter has
; a zener at Rx
; (OTW maybe use hZ
; AND add pull-up to 3V3)
;Then in iUART3V3:
; TxLOW =PORT7_WvL_RpL
; TxHIGH =PORT7_WvL_RpH
Eric Hertz
