Web Cockpit is available
- in the local network via the IP address of the Canique Gateway (no internet access needed) and
- on the internet via an https URL
Sensor values (including battery status and signal strength indicator) are updated live as soon as new measurements arrive. Widgets are automatically grayed out if no values arrive for a certain period of time.
Web Cockpit runs in all modern browsers: Tested on iPad Safari, Android Chrome, Linux Chrome
Features
- Gateway offline indicator (web version)
- Sensor outdated indicator (if no sensor values arrive for a certain period of time)
- Graph outdated indicator (if chart cannot be updated)
- Live sensor reading / battery status / signal strength / sensor label updates
- Switchable chart between temperature and humidity (by clicking on it)
- Regular automatic chart updates
- Automatic reconnect on connection loss
- Connection indicator (top right corner)
- Sophisticated configurable alarm triggers (notification via e-Mail) with javascript expressions
