For housing all the electronics I designed a external electronics enclosure. This includes:
- Safety electronics
- 24V and 5V power supplies
- Motor drivers
- power distribution PCB
- main IO and sensor PCB
The roboter is connected to the enclosure via a single connector. Peripherals can be connected via a secondary connector.
The electronics enclosure:
Front side with E-stop, on of switch, Led indicators and HMI connector
Backside with the described connectors for the robot and peripherals:
